Enabling HTTPS when using java webserver...
Postby fdullemond » Thu Mar 31, 2011 12:15 pm
I have successfully installed subsonic on a readynas, and I want to enable HTTPS for subsonic. Unfortunately the standard method of customizing the /etc/subsonic config file does not work.
On the readynas the subsonic server gets started by using following command line:
/c/webroot/subsonic/jre1.6.0_20/bin/java -Xmx700m -Dsubsonic.home=/c/webroot/subsonic -Dsubsonic.host=0.0.0.0 -Dsubsonic.port=4040 -Dsubson..........
Subsonic is started through a shell program which ultimately calls:
           /c/webroot/subsonic/jre1.6.0_20/bin/java -Xmx${SUBSONIC_MAX_MEMORY}m \
                -Dsubsonic.home=${SUBSONIC_HOME} \
                -Dsubsonic.host=${SUBSONIC_HOST} \
                -Dsubsonic.port=${SUBSONIC_PORT} \
                -Dsubsonic.contextPath=${SUBSONIC_CONTEXT_PATH} \
                -Dsubsonic.defaultMusicFolder=${SUBSONIC_DEFAULT_MUSIC_FOLDER} \
                -Dsubsonic.defaultPodcastFolder=${SUBSONIC_DEFAULT_PODCAST_FOLDER} \
                -Dsubsonic.defaultPlaylistFolder=${SUBSONIC_DEFAULT_PLAYLIST_FOLDER} \
                -jar /c/webroot/subsonic/subsonic-booter-jar-with-dependencies.jar > ${LOG} 2>&1 &[/i]
In order to enable HTTPS I changed the port line to
                -Dsubsonic.httpsPort=${SUBSONIC_PORT} \
Which seems to work fine, and a https connection is used. However following error occurs:
                     HTTP ERROR: 404
                     NOT_FOUND
                     RequestURI=/login.view
                     Powered by jetty://
So apparently other flags need changing as well.
Anyone can explain which flags I need to add/exchange to make HTTPS working ?
Fred
fdullemond
