Removing old files in the Android... (Subsonic wont do it?)
Postby imasterxx » Thu Mar 31, 2011 7:22 pm
Hello.
I read online somewhere that Subsonic doesn't automatically remove files that you've already listened to. Is this true? I don't have a lot of free space on my memory card and it's tedious to have to continue deleting songs in order to keep listening. Does anyone have a solution for this situation (other than to buy a larger memory card :p) It would be nice if the cache directory was a rolling cache directory, meaning it would keep the previous X number of songs that you listened to (and no more). As you listen to the songs, it removes the old ones.
Thanks.
imasterxx
Postby bushman4 » Thu Mar 31, 2011 7:35 pm
You can set the cache size onthe Android app, but the smallest you can set is 500mb I believe.
It will keep only as much as the cache limit.
I bought a 32gb card and set the cache size to 20gb. Now I have a 20 gig "iPod" at my disposal when I am out of netwrok range, and I know it is the 20gb I listened to last...
HTH,
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby imasterxx » Thu Mar 31, 2011 7:44 pm
Thanks, that makes sense. I'm still running with an 8gb card. me thinks its time to upgrade to atleast to a 16gb to avoid this (and other) space issues.
imasterxx
Re: Removing old files in the Android... (Subsonic wont do i
Postby denmalley » Tue Jun 24, 2014 8:26 pm
Anyone know why I might have a 9GB directory even though my cache size is set to 5GB?
denmalley
Users browsing this forum: Google [Bot] and 17 guests
