port forwarding
port forwarding
Postby dirkalberteverts » Sat Apr 02, 2011 6:40 am
Hello all,i really need some help with this.I seem not to get connected to the ss server outside my house.I tried everything and read all topics about this problem.
I made screenshots to make it easier for everybody to help me.
My ports are open,so here no problem.I use mandriva for OS.
[/img]
dirkalberteverts
Postby GJ51 » Sat Apr 02, 2011 3:26 pm
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080 - 440, 8081 - 441, etc.
Postby dirkalberteverts » Sun Apr 03, 2011 5:15 am
when i type in my name.subsonic.org:8080 i see that my name changes to my internal ip adress where the subsonicserver runs on.Shouldn that be my external ip adress?
dirkalberteverts
Postby GJ51 » Sun Apr 03, 2011 3:06 pm
Doesn't really matter as long as you can connect. If your inside your network, some routers automatically translate to the internal ip.
Postby bushman4 » Sun Apr 03, 2011 5:05 pm
Just a quick point that I noticed...
When connecting to your redirected subsonic.org address (ie the name.subsonic.org address) you DO NOT NEED THE PORT NUMBER AT THE END OF THE URL!
If your registered Subsonic.org name is pickle.subsonic.org and your server is running on port 1234, the proper address is "http://pickle.subsonic.org" NOT "http://pickle.subsonic.org:1234."
The Subsonic.org servers then see this as an HTTP request for your subsonic.org domain name and redirect your browser to your current external IP address, and the port, and context path that Subsonic is running under.
Just want to be clear... it is VERY possible that Sindre's servers are only configured to respond to requests on the standard Web Ports and any attempt to contact "http://pickle.subsonic.org:1234" would fail.
HTH,
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby GJ51 » Sun Apr 03, 2011 5:28 pm
Thanks Glenn,
That's correct. The Subsonic.org server translates the Servername.subsonic.org request into the ip:port# of the server it is requesting. The port number should NOT be appended to the Subsonic.org address. When you save the network settings, the local SS instance transmits the IP and port number to the Subsonic.org server. When you access your server with the http://servername.subsonic.org, it uses that information to transmit the request back to your local server using the correct ip and port number.
Also remember that you can't make a direct https connection using the subsonic.org address. The Subsonic.org server only uses the http address, but Subsonic will respond to the request over ssl if you have it enabled. You can make a direct connection to the ssl port if you use your external ip and port number, or if you use another DNS server that will accept https requests. This works with WHS. e.g. https://maplegrove.homeserver.com:442
