last.fm
last.fm
Postby johnwhitney » Sun Apr 03, 2011 5:11 am
Problem Description: after entering my last.fm un/pw and clicking save, the screen flashes and I'm sent to the "playing" screen. Back in settings, the last.fm username is saved, but not the password.
Troubleshooting Steps: Searched this and last.fm forums
Playback Application and version: From the web (tried in both Chrome and IE9)
Subsonic Version: 4.4 (build 2172) – February 6, 2011
Server Version: jetty-6.1.x, java 1.6.0_23, Windows 2003 (37.0 MB / 67.8 MB)
Hardware Platform: Windows Home Server
Java Memory Limit: 31 mb
Problem Filename: none
Output from ffmpeg -i: this does not work
Last ten log file lines: there's nothing interesting there, just me playing music
johnwhitney
Postby bushman4 » Sun Apr 03, 2011 4:47 pm
I believe that is by design. Mine shows the field empty too, but the scrobbling is working fine.
To double check, go to http://Your.Subsonic.IP.Address:port/db.view and enter the command "select * from user_settings" and see if the Last.FM Password box has an encoded string in it. If so, it has saved the password.
HTH,
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby johnwhitney » Mon Apr 04, 2011 1:11 am
Yes! I'm too used to seeing ******* password fields!
johnwhitney
