Userlogs in V 4.4
Userlogs in V 4.4
Postby Elsi29 » Sun Apr 03, 2011 1:40 pm
where i can find in V4.4 build 2142 the Userlogs?
Thx for answers
Server: Atom D525, 4 GB RAM, 1,5 TB HD, Win 7 Prof. 64 Bit, Pico PSU, Power 25 Watt
FRITZ!Box 7390
Subsonic 4.9.beta4
Internet: 51 MBits Down / 9,5 MBits Up
Elsi29
Postby Elsi29 » Mon Apr 04, 2011 5:02 am
Nobody an Idea???
FRITZ!Box 7390
Subsonic 4.9.beta4
Elsi29
Postby Minime » Mon Apr 04, 2011 10:43 am
Check the "About" page in subsonic to view the latest logs. If you want to view the entire log file, then scroll all the way down to see the full path. This depends on your OS. Mine is Ubuntu and it is located in: /var/subsonic/subsonic.log
Best Regards
Minime,
Subsonic 4.6 | Ubuntu 10.04 LTS inside a VMWare host
Galaxy SII with ICS 4.0.1 & Android App v3.0 Combo
XBMC Dharma with t0mm0-xbmc-addons
+ A few custom Mods
Minime
Postby Elsi29 » Wed Apr 06, 2011 5:20 am
This Logs i have seen. But what I want to know is, where I can see, when a User logs in and what this User have streamed or downloaded.
Can I see this in other Logs???
An other Question:
I have 3 Albums from "Noah and the Whales". They are listed at the left Side from Subsonic. But when I search for the Names of the Band or from Titles from the Band, Subsonic founds nothing. Everytime when I search for "Noah" or "Whales" comes Results from other Bands, but not "Noah and the Whales".
FRITZ!Box 7390
Subsonic 4.9.beta4
Elsi29
Postby Minime » Wed Apr 06, 2011 6:46 am
The logs are for everything.You can see which user streamed/downloaded what etc(dont think you can see a user log in and not streaming/downloading a file?). These logs are only displayed for the last x number of incidents(not sure of number) and if you need to go back further, you check the log file itself.Look for its path at the bottom of page.
Regarding the search. Did you initiate a full search of your media in subsonic? Go to settings--Search and let it do a full scan, the try again.
Best Regards
Minime,
+ A few custom Mods
Minime
