Server Connection
Server Connection
Postby beckeyg » Sun Apr 03, 2011 11:36 pm
In my settings my port forwards fine to port 80, however my server status continues to show as registered but could not connect to it "Connect Timeout Exception". Why will it not show as a successful registered connection?
beckeyg
Postby GJ51 » Mon Apr 04, 2011 1:48 am
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080 - 440, 8081 - 441, etc.
