Disable playlist auto advance
Postby Twanks » Mon Apr 04, 2011 6:18 pm
After using the forum search feature, Google, and (hopefully) after me not seeing the feature in the Subsonic webplayer, I would like to know how to disable the software from automatically going to the next song. I'm thinking there should be a value somewhere that I can edit, but if I can not fix this problem it will be a deal breaker for what is otherwise incredible software. Thanks for your time.
Twanks
Postby GJ51 » Mon Apr 04, 2011 8:41 pm
Just don't add the tracks to the player que. You can select an Album, it will list the tracks in the upper window. In the upper window you can play each track individually. I'm sure you could create folders with the tracks you want and do the same thing. I have a folder "Singles" that I throw all odd tracks into. It works fine this way. Just play everything from the > arrow in the upper window, instead of adding to the player que.
