Can you access my Subsonic server? Please?
Postby mscrutchin » Tue Apr 05, 2011 7:01 am
I'd be grateful if someone could test my link and let me know if you can access it.
EDIT: OK, it works, so I've taken the link down and removed the guest account. Thanks for your help! :)
I can access it just fine from within my network and everything seems to be working properly on my end.
I have a Netgear WNR3500L router and I have UPnP turned on and working. My Subsonic server is on an iMac running Mac OS X 10.6.7. In Subsonic's SETTINGS under Network, I have it checked to automatically configure my router via UPnP and it tells me "Status: Successfully forwarding port 4040" (CanYouSeeMe.org also reports success on port 4040). [I tried to manually forward the port and I'm 99% sure I did it right, but I got "Status: Port forwarding disabled," so I'll leave it to UPnP for now.] And it also says "Status: mscrutchin.subsonic.org responded successfully," so that should be OK. Oh, and I configured my router to give my iMac a static IP address.
Router: Netgear WNR3500L (Firmware Version: V1.2.2.30_34.0.37NA)
Subsonic Version: 4.4 (build 2169) – February 6, 2011
Server Version: jetty-6.1.x, java 1.6.0_24, Mac OS X (41.6 MB / 81.1 MB)
Hardware Platform: Mac OS X 10.6.7
Java Memory Limit: 256mb
Please tell me you guys can access it and login with my "guest" username and password.
I'm gonna donate as soon as I'm sure everything's working. :)
mscrutchin
Postby mscrutchin » Tue Apr 05, 2011 7:18 am
Thanks for whoever popped in and sent a chat message letting me know it works. :)
Just donated. Please, Subsonic, don't ever go away!
mscrutchin
Postby utopian » Tue Apr 05, 2011 11:55 am
yep i can get in..:)
utopian
Postby mscrutchin » Tue Apr 05, 2011 6:21 pm
Thanks for all your help, guys. :)
mscrutchin
