error popup
error popup
Postby mts » Thu Apr 07, 2011 7:21 pm
Tried to search this but at least for quick look dint found any help.
So my problem is that when i sign in to site i get popup message saying error and there is also ok button to remove it but no other info.
Some times i have noticed that this comes twice.
Also same time when this started there is no "now playing section" whit users anymore either. Other wise it seems to be working fine but this small thing is bit annoying.
So have anyone else had this same problem and what i could to do fix this.
Im using version 4.4. (build 2169)
Im running on Centos, jetty-6.1.x, java 1.6.0_17
Any advices would be appreciated.
mts
Postby baaldemon » Fri Apr 08, 2011 1:51 am
This used to happen occasionally, but has now started up again and now is consistent every time I login.
It hasnt annoyed me to the point where I have wanted to debug it since it only happens initially when I log in. The error appears to be just a standard js error, so shouldnt be much more than firing up firebug to see exactly where its coming from. If I get some time I will try and run through and figure out what the hell is causing it to happen.
Im running a custom built version of 4.4 (just some modified logging techniques and custom last.fm scrobbling crap but mostly stock) through tomcat6 on openSuse 11.2 x64 1.6.0_20
baaldemon
Postby mts » Sat Apr 09, 2011 7:57 am
Seems that restarting subsonic worked for now.
mts
