cant get m3u playlists with stream URLs anymore...
Postby mtakacs » Sat Apr 09, 2011 8:48 pm
super short version:
Anyone know what might have changed that my "play album" request is now generating zips of mp3 instead of generating a m3u playlist with streams?
(full details in next post)
-Mark
mtakacs
Postby mtakacs » Sun Apr 10, 2011 6:46 pm
Problem Description: i used to get m3u files that referenced streams,now I get zips of mp3 files
Troubleshooting Steps: see below
Playback Application and version: VLC 1.1.8
Subsonic Version: 4.4 (build 2169) – February 6, 2011
Server Version: jetty-6.1.x, java 1.6.0_20, Linux (120.3 MB / 189.6 MB)
Hardware Platform: readyNAS plugin, Released by Super-Poussin v2.0.00
Output from ffmpeg -i:
FFmpeg version UNKNOWN, Copyright (c) 2000-2011 the FFmpeg developers
  built on Mar 20 2011 21:32:23 with gcc 4.3.2
  configuration: --enable-pthreads --disable-shared --enable-static --enable-gpl --enable-libx264 --enable-libmp3lame
  libavutil     50.36. 0 / 50.36. 0
  libavcore      0.16. 1 /  0.16. 1
  libavcodec    52.108. 0 / 52.108. 0
  libavformat   52.93. 0 / 52.93. 0
  libavdevice   52. 2. 3 / 52. 2. 3
  libavfilter    1.74. 0 /  1.74. 0
  libswscale     0.12. 0 /  0.12. 0
Loving my subsonic installation. After upgrading to 4.4 the other day, the behavior of my player has changed.
my previously experience
    * I'd go to the subsonic webinterface
    * click one of the albums on the homepage
    * click "play all"
    * which would trigger my "vlc" player profile
    * This seemed like it would download a play-01.m3u file
    * my mac launched VLC
    * VLC opened the streams
These files contained stuff that looked like:
#EXTM3U
#EXTINF:187,Toby Keith - She's A Hottie
http://192.168.1.15:4040/stream?player=4&pathUtf8Hex=2f632.....7033&suffix=.mp3
#EXTINF:240,Carrie Underwood - Last Name
http://192.168.1.15:4040/stream?player=4&pathUtf8Hex=2f632f6d6......6d7033&suffix=.mp3
I cant seem to get subsonic to generate those downloads anymore. It keeps trying to
a) download as a playlist t and resolve all the references into the actual MP3 files, generating a ZIP file containing mp3s (not what I want)
b) plays in the browser (not what I want)
When I look at the last seen player settings, they show up as:
Type    QuickTime/7.6.6 (qtver=7.6.6;cpu=IA32;os=Mac 10.6.7)
Last seen   April 9, 2011 1:17:11 PM
which is NOT what I want, that seems to subsonic trying to hand off to quicktime, not VLC.
I've tried to reconfigure the player in different ways:
web / external / external+playlist / juekbox
but I cant seem to get it right. My best guess as to how it should be configured is:
    * external player
    * cover art: medium
    * max bitrate : no limit
    * player has dynamic IP: checked
    * control player automically: checked
    * active transcodings: (all, default)
I dont want to broadcast to a player, Id like it to go back to generating a playlist that will allow my player to connect. (when I use the old playlists that got downloaded to my Downloads dir, they works fine)
log after using a stream url of - http://192.168.1.15:4040/stream?
[4/9/11 1:42:31 PM PDT]   INFO   StreamController   Got range: Range[0,9223372036854775807]
[4/9/11 1:42:31 PM PDT]   INFO   PlaylistInputStream   admin listening to "Part II [2001]/02 I'm Gonna Miss Her.mp3"
any idea what I might have to do in order to get back to having subsonic hand me stream playlists that I can use in VLC?
or if I do have to subscribe to a stream, where can I get the URL (mUrl?) of the stream so I can put it into VLC's "play network stream"
or am I fundamentally misunderstanding the model of how I'm supposed to listen to my music thru subSonic?
-Mark
mtakacs
Postby tox » Sat May 07, 2011 4:04 pm
same problem here :'(
tox
Postby GJ51 » Sat May 07, 2011 9:04 pm
When you select external player with playlist SS hands off the request to the default desktop player. Is it possible that a quicktime update redefined the default player?
Postby mtakacs » Sun May 08, 2011 3:03 am
oddly enough, if I access Subsonic using MacOS Safari, the selected playlist / album does indeed trigger VLC with a list of streaming URLs. I am happy.
If I access Subsonic using MacOS Chrome, I get the unexpected behavior described above. I am sad.
I'm not sure why Chrome would behave so badly, but since I have a workaround (use Safari for launching my albums / playlist), I'm ok. Not entirely sure what might have happened tho.
mtakacs
