mp3 genre numbers not converted
Postby piethein » Sun Apr 10, 2011 3:20 pm
Somehow subsonic does not display the genre on mp3s, but the genre number (for example '8' instead of 'jazz' or '20' instead of 'alternative'). I believe subsonic had converted the number to the corresponding genre-text in earlier versions, but I am not sure. Can this be fixed? If I can do something to help isolate the bug(?), I will do my best.
piethein
Postby jaquense » Mon Apr 11, 2011 3:05 pm
As far as I can gather it is an ID3 tag bug with v2.4 tags. make sure you save as v2.3 (with what ever you use to tag files) and that should solve your problem
jaquense
