How to change default folder listed when logged in?
Postby demonstreamer » Mon Apr 11, 2011 3:05 pm
Whenever I login, my "Rock" folder is displayed on the left hand side. I want this to be the "All Folders" option.
How do I change this?
demonstreamer
Re: How to change default folder listed when logged in?
Postby Aethies » Mon Apr 11, 2011 7:13 pm
demonstreamer wrote:Whenever I login, my "Rock" folder is displayed on the left hand side. I want this to be the "All Folders" option.
I think this is cached by your browser. I am not sure how to change it to be all folders. I think if you clear your cache, that might work. Or just change it to all folders and then hit the log out button.
Aethies
Ubuntu Server 12.04
3,281 artists
9,432 albums
113,608 songs
2636.09 GB (10,769 hours)
Aethies
Postby demonstreamer » Thu Apr 21, 2011 9:32 pm
BUMP.
Clearing the cache doesnt work.
This is very annoying. Anyone have a fix?
demonstreamer
Postby bushman4 » Fri Apr 22, 2011 6:38 pm
I believe it is the SELECTED_MUSIC_FOLDER_ID value in the user settings table.
What should be the easy way: Switch to "All Folders" and log off Subsonic, then log back on.
The "dirty" way, navigate to the db.view page (http://Your.Subsonic.Address:Port/db.view) and enter the following command:
Update User_Settings set SELECTED_MUSIC_FOLDER_ID=-1 where USERNAME='DesiredUsernameToAffect'
HTH,
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
