Problems installing to transcode folder
Postby Nakaan » Tue Apr 12, 2011 3:11 pm
I recently installed Subsonic 4.4 Standalone onto a desktop running ArchLinux. I used pacman to install LAME and ffmpeg, but I can't transcode video or downsample music (rendering my phone useless due to low bandwidth haha). I read that you're supposed to install these programs to the transcode folder within SUBSONIC_HOME (which I would assume is the directory where Subsonic is installed), but I don't know how to do this.
My question: how do I install ffmpeg and LAME from source into the transcode directory?
Thanks for the help, guys ^_^
Nakaan
Postby baaldemon » Tue Apr 12, 2011 3:31 pm
Just use symbolic links so that they are in /var/subsonic/transcode rather than actually installing them there.
ln -s <fileToBeLinked> <NewLocation>
example if lame exists as /usr/bin/lame
ln -s /usr/bin/lame /var/subsonic/transcode/lame
Make sure the user you run the command as has correct privileges on the transcode directory
baaldemon
Postby Nakaan » Tue Apr 12, 2011 3:39 pm
Thanks to the power of SSH and DynDNS your solution is implemented, tested, and working ^_^ Thank you very much, sir!
EDIT: Could a mod mark this a solved, please?
Nakaan
Users browsing this forum: Bing [Bot] and 20 guests
