help with android client
Postby gmoney91 » Fri Apr 15, 2011 5:03 am
Subsonic works fine for me on the PC, but as for my android phone I can only get it to work when I'm using wi-fi. Any suggestions on why this is happening? It was working without wi-fi when I first starting using it. Then, it I didn't use Subsonic for awhile until I finally decided to donate. I haven't got it working without wifi since.
gmoney91
Postby GJ51 » Fri Apr 15, 2011 1:29 pm
Does it work on the SS Demo server?
Postby gbaker49 » Sat Apr 16, 2011 2:08 pm
I am having the same issue, and yes the Subsonic demo server works fine.
WIFI works great, but over 3G I get network error when the phone tries to connect my pc server. I may have something set up wrong. Thanks for your help
gbaker49
Postby GJ51 » Sat Apr 16, 2011 2:42 pm
This is most commonly due to port forwarding on the router not being set up correctly.
Go to http://www.canyouseeme.org/ enter your SS port number and click the Check box to be sure the Subsonic port is open.
Postby gbaker49 » Sat Apr 16, 2011 2:50 pm
It says it's not open, so does this mean I need to get a static IP address and go through all that. I'm somewhat technical, but I haven't played around with that kind of stuff.
gbaker49
Postby gbaker49 » Sat Apr 16, 2011 2:51 pm
gbaker49
Postby GJ51 » Sat Apr 16, 2011 2:53 pm
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080 - 440, 8081 - 441, etc.
Postby gbaker49 » Sat Apr 16, 2011 3:04 pm
Thanks for the quick response, I will go into more depth and learn about my IP and my router using the resources you suggested. Thanks for taking the time to explain it.
I will let you know how I make out
gbaker49
Postby gmoney91 » Tue Apr 19, 2011 1:35 am
I'm using port 8080, and it say's it cannot see my service, connection refused. I'm gonna go through the tutorials again and let you know I come up with.
gmoney91
Postby GJ51 » Tue Apr 19, 2011 2:10 am
Make sure you understand your router's manual.
Postby gmoney91 » Tue Apr 19, 2011 2:37 am
Ok, I got it working. Thank you for your help.
gmoney91
Postby GJ51 » Tue Apr 19, 2011 2:58 am
Glad to hear you've got it working. Most of these problems are in the router setup. Unfortunately, there are no easy answers when it comes to understanding the router, as every mfgr. uses its own interface. Most of the major mfgrs. are pretty easy to follow, but get on of the routers that Verizon uses for FIOS and you can drive yourself crazy for days. Carefully reading, and understanding your particular router's maunual is the only way to get competence in managing your particular network configuration, ip configuration, and port forwarding.
Postby DrClaw » Thu May 26, 2011 8:56 pm
So, I recently moved. Subsonic was working great before, I could access it from outside networks and all. However, I moved to a new house, same ISP, same router settings and for some reason can'd access it from a different network OR 3g on my phone. My port is forwarded correctly, I have no idea why its not working. I can still access if when IM in the same wifi network, but nowhere else. The port is open according to canyouseeme.org and I dont know what else the problem could be. My router is a lunksys wrt54g if it helps
DrClaw
Postby GJ51 » Thu May 26, 2011 9:56 pm
What port are you set up on?
Postby DrClaw » Fri May 27, 2011 12:15 am
Its set up on port 8079.
The old setup (before I started messing with it after the move) was 8080 which worked with no problems. Emphasis on the past tense
Apparently the html is working, as my friend was able to login from across the country. So I guess its just the android client that isnt working??
DrClaw
Users browsing this forum: No registered users and 113 guests
