Do I need a fixed IP to use subsonic?
Postby richardf » Sat Apr 16, 2011 12:39 pm
Getting the standard connection error when I try to connect.
Status: grandebleu78.subsonic.org is registered, but could not connect to it. (ConnectTimeoutException)
I'm using the default ports 4040 and this ok (according to the UI)
Status: Successfully forwarding port 4040.
Any thoughts or advice on what to check?
(running on Ubuntu if that's of interest)
cheers,
- Richard
richardf
Postby GJ51 » Sat Apr 16, 2011 3:00 pm
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080 - 440, 8081 - 441, etc.
Postby alphawave7 » Sat Apr 16, 2011 7:04 pm
Gary's post distilled: you need a fixed lan IP for your server. You need a port opened (manually is best) on your router. :) Test that port to verify it works using canyouseeme.org.
Postby davidthomp84 » Sat Apr 16, 2011 8:18 pm
yes you do need a static IP in order for server to be available at all times. By default routers will assign IP's dynamically which means that once you restart your computer your router could assign a different IP from before automatically. I haven't done this in unbuntu but setting a static IP is essential in making sure u can always hit your server. Without a static IP hitting your server would be like a moving target because ur IP can change. Also setting Port Forwarding would be useless without a static IP.
In windows you actually can change ur Ip to static, without going into the router settings. Under change adapter settings. Right-click Local Area connection and go to properties under there u can see that automatically assign. Click that off a manually set it up. All information for settings can be found under IP config /all in command prompt. Try to set your static IP to a couple digits off of your default gateway, which if you didn't know is the IP of your router. Example:
default gateway: 192.168.1.1
Static IP should be set to something like: 192.168.1.158
I know settings are different in ubuntu but i'm sure you can figure it out.
Hope this helps
davidthomp84
Postby richardf » Sat Apr 16, 2011 11:30 pm
Thanks for all the replies guys! Really appreciate the detailed responses. Correct, it is time to sort out my home network. But if I've learned anything it's to address one particular thing at a time.
Since I've just moved to Ubuntu I'm cautious of messing around with the setup too much until I've found my feet.
Anyway, ignoring my cautious nature. Will the fact that I'm using an Apple BaseStation as a wireless AP have any impact on the advice you give?
Cheers,
Richard
richardf
