Cannot get to Subsonic from outside on a Netgear ReadyNAS
Postby MutantPixel » Mon Apr 18, 2011 9:40 pm
I've installed the Subsonic extension application to my Netgear ReadyNAS server and I can get it to work perfectly inside my house, but outside I cannot. I've poured over the IP settings and I'm almost positive I have the port forwarding and such set up properly, but still it doesn't work and my 30 day trial is about to expire. The only thing I can guess now is that my ISP (AT&T) is blocking port 4040 (??) I cannot for the life of me figure out how to change the port in Subsonic in the ReadyNAS, anyone have some ideas that could help out, I'd really super appreciate it. Thanks.
MutantPixel
Postby alphawave7 » Mon Apr 18, 2011 9:53 pm
The ReadyNas needs a fixed IP. In the router settings, use the fixed IP as your source for opening 4040...tcp. Test with canyouseeme.org until it is working on 4040..then test with your public IP:port and then your subsonic.org addy.
Postby MutantPixel » Mon Apr 18, 2011 10:01 pm
I have assigned a static IP to the ReadyNAS. Are you suggesting that by changing it to a different Static IP that is may work?
MutantPixel
Postby alphawave7 » Mon Apr 18, 2011 10:15 pm
MutantPixel wrote:I have assigned a static IP to the ReadyNAS. Are you suggesting that by changing it to a different Static IP that is may work?
Negative. Does canyouseeme.org report 4040 as open?
Postby MutantPixel » Mon Apr 18, 2011 10:40 pm
Thank you for the help Alphawave. I'm not at home right now so I cannot check for certain, but I'm pretty sure canyouseeme reported that the connection had timed out.
MutantPixel
Postby GJ51 » Tue Apr 19, 2011 1:00 am
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080 - 440, 8081 - 441, etc.
Postby MutantPixel » Tue Apr 19, 2011 1:08 am
GJ51 wrote:Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080 - 440, 8081 - 441, etc.
Thanks much guys, I do appreciate the help. I've been at this now for a couple weeks. I'm fairly adept at the networking stuff, and I'm virtually certain all is set right. All my troubleshooting points at the port being blocked. What I need to know is where is this control panel for Subsonic on the Netgear ReadyNAS so I can change the port? There's got to be some way to change it, I just can't find it. Thanks-
MutantPixel
