Can't access from outside LAN
Postby tismon » Tue Apr 19, 2011 2:03 pm
Problem Description: Can stream fine while within my LAN, but can't access anything from outside
Troubleshooting Steps: Port forwarding is setup correctly on port 5671 (manually and set as so in the subsonic settings) and canyouseeme can in fact see me. I've looked over the tutorials just in case, but nothing's helped yet. I set a static IP for my computer in my LAN about 2 weeks after installing, but I'm not sure if I have to update something on subsonic's end.
Playback Application and version: Standard Subsonic Web Interface & android application
Subsonic Version: 4.4 (build 2172) – February 6, 2011
Server Version: jetty-6.1.x, java 1.6.0_21, Windows 7 (43.5 MB / 71.5 MB)
Hardware Platform: Windows 7 Pro 64-bit
Java Memory Limit: 100MB
Last 10 log file entries:
[4/19/11 8:09:35 AM CDT]   INFO   DaoHelper   Checking database schema.
[4/19/11 8:09:35 AM CDT]   INFO   DaoHelper   Done checking database schema.
[4/19/11 8:09:36 AM CDT]   INFO   SearchService   Automatic index creation scheduled to run every 1 day(s), starting at Wed Apr 20 03:00:00 CDT 2011
[4/19/11 8:09:36 AM CDT]   INFO   PodcastService   Automatic Podcast update scheduled to run every 24 hour(s), starting at Tue Apr 19 08:14:36 CDT 2011
[4/19/11 8:09:42 AM CDT]   INFO   NetworkService   Deleted port mapping for port 80
[4/19/11 8:09:43 AM CDT]   INFO   NetworkService   Deleted port mapping for port 443
[4/19/11 8:14:36 AM CDT]   INFO   PodcastService   Starting scheduled Podcast refresh.
[4/19/11 8:14:36 AM CDT]   INFO   PodcastService   Completed scheduled Podcast refresh.
[4/19/11 8:59:13 AM CDT]   INFO   VersionService   Resolved local Subsonic version to: 4.4
[4/19/11 8:59:13 AM CDT]   INFO   VersionService   Resolved latest Subsonic final version to: 4.4
[4/19/11 8:59:13 AM CDT]   INFO   VersionService   Resolved latest Subsonic beta version to: 4.4.beta1
I'm not too sure where to go from here. I'd definitely donate if this proves to be something reliable once it's setup.
Thank you for any help.
tismon
Postby GJ51 » Tue Apr 19, 2011 2:47 pm
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080 - 440, 8081 - 441, etc.
Re: Can't access from outside LAN
Postby tismon » Mon Aug 29, 2011 6:02 pm
Well, I didn't respond before for a few reasons including that it started to work with no change on my part. I have a feeling that there was something done behind the scenes and that's what I'm hoping it will come to again.
I've now installed the server on a different computer and have completely uninstalled it on the first. At first it worked, until my ISP changed my IP address again and subsonic didn't update. I can still type in the address with the right port and use it, but I would much rather be able to use the dynamic dns updater within subsonic as it seems my IP address gets changed about every week. Any ideas?
Also, I just wanted to add, this is an amazing service and if it ever dies, I will be using it with no-ip for many years afterwards. You've done a great job!
tismon
Postby GJ51 » Mon Aug 29, 2011 6:28 pm
You should be able to resend your ip whenever it changes by going to Settings/Network and clicking the Save button.
Postby bushman4 » Mon Aug 29, 2011 6:29 pm
Just restart the subsonic service and it will re-register with the subsonic redirect server. It may take five minutes or so to actually work correctly.
HTH,
Glenn
Added: or do what Gary says to do, although I seem to remember that the save button has a check to only re-register if the custom domain name changed...
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby tismon » Thu Sep 01, 2011 2:20 pm
Well, tried all of that and upgraded to 4.5, but it's still not working.
tismon
Postby bushman4 » Thu Sep 01, 2011 2:37 pm
What custom domain name are you using?
If you are outside your lan and enter that custom domain name, it should redirect you to an IP address and port combination. Are those correct?
Let me know,
Glenn
Glenn Sullivan
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby tismon » Thu Sep 01, 2011 3:16 pm
No, those still reflect an old ip address.
tismon
Postby GJ51 » Thu Sep 01, 2011 3:47 pm
When you go to Settings/Network and hit the Save button, what message do you get on the Status: line just below the entry for your site name?
Is the boxed checked for "Access your server over the Internet using an easy-to-remember address."?
Sorry if I seem to be asking the obvious, but oftentimes it's the obvious that we overlook.
Also, after rereading your original post, did you change the port numbers, or are you still using 80,443?
Postby tismon » Tue Sep 06, 2011 2:13 pm
Although I think you were onto something GJ51 and part of the problem is that I was just that blind, I think there is/was more going on. Aside from that, when I tried to change anything in the control panel (not in browser), it gave me a could-not-write-settings error and I couldn't start/stop the service from there. That's now cleared up after a fresh re-install, and I've now got the in-browser settings ironed out, but there's one last thing.
It doesn't seem to recognize my account. It says that I'm still using the trial (donated a few months or more ago) and I get "The web address "tismon" is already in use. Please select another." The e-mail for my admin and my own username is correct. Is there anything else I can check/change?
tismon
Postby bushman4 » Tue Sep 06, 2011 2:22 pm
Re-enter your unlock code from Sindre when you donated...
I think Sindre would have to remove the existing mapping for tismon for you... Even changing it and changing it back probably won't work because there is no "unregister" being sent for tsimon...
Initially I thought that might work, but the system is obviously set up so that people can run multiple servers from the same IP address (Gary for example...) so there is no "global unregister" that happens when a new registration comes in from an IP address that is already in the redirect table.
HTH,
Glenn
Glenn Sullivan
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby tismon » Tue Sep 06, 2011 2:30 pm
Wow, I am scatterbrained. I completely forgot about that code.
I'm sorry for wasting your time, but thanks for sticking with me on this. Everything seems to be working again.
tismon
Users browsing this forum: Google [Bot] and 23 guests
