Music without decoding
Postby micalb » Wed Apr 27, 2011 8:00 am
First of all i'm very happy with how subsonic works. It does the trick very well for me.
I would like one option though.
Can anyone tell me if it is possible en how to stream flac musicfiles over a local network without decoding it to mp3?
I've tried to uncheck te decoding box but then i heard nothing.
micalb
Re: Music without decoding
Postby micalb » Wed Apr 27, 2011 1:22 pm
micalb wrote:First of all i'm very happy with how subsonic works. It does the trick very well for me.
I did mean transcoding in the text above
micalb
Postby kermit22 » Wed Apr 27, 2011 3:13 pm
If you change your settings so that you play your music through an external player then you will be able to as long as that external player supports flac format.
in the web interface go to Settings>Players>External player
The other option is to convert flac>wav
See this thread:
http://forum.subsonic.org/forum/viewtopic.php?t=5546
kermit22
Postby micalb » Fri Apr 29, 2011 11:34 am
Thanks for the advice, it works well for me this way!
micalb
Users browsing this forum: Google [Bot] and 28 guests
