Welcome screen artwork problem
Postby TweakEn » Fri Apr 29, 2011 12:21 am
I just reformatted my hard drive and reinstalled subsonic and now I can't see random/recently added/top rated....etc artwork on the welcome screen. Anyone know how to get this to work? I can see album art at each individual artist link, just not on the home screen. Thanks
TweakEn
Postby inn3rligh7 » Sat Apr 30, 2011 5:28 am
i have definetly the same problem.... as reinstalling or formatting or upgrade seems the troublemaker here... maybe the programm cant find the dir were all thumbs are stored? if we know how the programm shows the 10to50 links in the hometab then we were a bit deeper in this troublesolving.but i cant read the routines.
sry for this english.
maybe a step for step reinstall will help, but how? the solutions here in the faq is most for linux user. not for winxp machine....
inn3r
p.s. so pls guys help us in fixing this, even with a detailed upgrade or reinstall step instruction. thx
inn3rligh7
Postby reaper829 » Mon May 02, 2011 4:59 pm
You probably need to run the index. had the same problem. login as admin and go to search > index. You should be fine then.
reaper829
Postby TweakEn » Fri May 06, 2011 12:38 am
actually it fixed itself on its own somehow.... weird.... I'll remember to try that tho if it happens again, thanks
TweakEn
Postby 3R3 » Fri May 06, 2011 11:43 am
It didnt actually "fix itself on its own", but the index rescan is set to run every 24h on some time I cant remember right now by default. So thats all that happened, it never was broken ;-)
3R3
