Ubuntu Subsonic not installing
Postby Bray90820 » Sun May 01, 2011 7:12 pm
so every time i try to install subsonic on ubuntu 11.04 it says The package is of bad quality and it gives me the option to ignore and install when i do that it installs but is nowhere to be found
Bray90820
Neophyte but will try to help
Postby anjenaire » Mon May 02, 2011 1:05 am
So I just went through the same thing. I eventually plugged some commands into a terminal window for the Ubuntu tutorial and got it up and running. I find the software center a tad flacky. I tried the ignore command as well but I had to use the Steps 1 and Steps 3 of the post http://forum.subsonic.org/forum/viewtopic.php?t=1486 to complete the install. I made sure that my java was correct and then started Subsonic in a command line. A few reboots and it is up and running. I can't seem to make it find my music however. so .....
anjenaire
