Albums not showing in Home & User statistics not working
Postby Spartacus » Sun May 01, 2011 8:18 pm
Hey,
I've recently installed Subsonic. I believe I have configured it well, as everything is working great except the albums don't show when I'm in the 'Main' tab.
Even though I've added album covers for all my songs.
Is there a reason why this does not work?
Also, another problem.
Why does it now show me the user statistics?
Server details:
jetty-6.1.x, java 1.6.0_17, Linux (31.3 MB / 46.0 MB)
Spartacus
Postby GJ51 » Mon May 02, 2011 12:39 am
Probably hasn't been indexed yet. Go to Settings/Search and click on Update search index now. Give it 15 min. Indexing time depends on the size of your library.
Postby Spartacus » Mon May 02, 2011 7:34 am
You were right, the albums do show now when it has been indexed :)
The user statistics function does not work yet though. Any tips on how to fix that?
Spartacus
Postby GJ51 » Mon May 02, 2011 3:04 pm
That too, should resolve itself. Give it some more time.
Postby Spartacus » Wed May 04, 2011 1:23 pm
Alright. I'll give it a couple of days.
Another question:
I've been trying to search for a function that would allow users to sign up themselves, so I don't need to add them manually. Is there such a function?
Spartacus
Postby GJ51 » Wed May 04, 2011 3:14 pm
Not at this time. I use generic guest and visitor accounts that I give to people who wnant to visit my sites. You can create different generic accounts with different Privelege levels. Not ideal, but workable. Creating definable access rights to each directory on a per user level has been suggested many times.
I'm not sure about the "user statistics." That's an issue I've never had a problem with. You might try a forum search to see if anyone else has encountered it before.
Postby Spartacus » Sat May 14, 2011 12:40 pm
Alright. I've given it plenty of time but it's still not working. I've also searched the forums, but the best tip I found was to restart the server. I did that, but didn't help at all.
Any ideas?
Spartacus
Postby GJ51 » Sun May 15, 2011 10:59 pm
I'm a Windows guy. If I was where you're at, I'd uninstall SS through Control Panel/Programs and Features, uninstall Java and delete C:\Subsonic. Then start with a fresh Java install to the latest version. If you use a 64 bit browser be sure to get both 32 & 64 bit Java.
http://www.java.com/en/download/manual.jsp
Then reinstall SS.
It's also a good idea to do a reboot just before reinstalling Java and SS.
Postby Spartacus » Tue May 17, 2011 3:38 pm
Alright. I'm running Subsonic on Centos 5.5.
I'm also getting an Error message while signing it. Weird.
Spartacus
Postby GJ51 » Tue May 17, 2011 3:44 pm
Delete the browser cache.
Postby Spartacus » Fri May 20, 2011 12:45 pm
It happens on any computer, so there is no browser cache involved.
Spartacus
Postby GJ51 » Fri May 20, 2011 2:12 pm
I've seen this happen occasionally on my servers. Stopping the SS service and restarting it usually fixes it. Perhaps rebooting the server would help.
