Warning: No network available when downloading or straming
Postby rafadc » Tue May 03, 2011 1:54 pm
I set up a server in my windows machine to be accessed in LAN only. I want to access the machine connected to my private wifi.
The problem is that i am able to use web interface or to browse songs from my android phone but if I try to download or stream any song I get an "Warning: no network available" error.
Also if I test connection it gives unlicensed but connection OK. I
Any ideas where I can look?
Thanks a lot in advance.
P.S. : I'm checking everything works in my config before licensed so my server is not licensed yet. I think that license is not neccesary for 30 days, isn't it?
rafadc
Postby alphawave7 » Tue May 03, 2011 3:52 pm
Use Airplane mode, then turn on wifi only. Does that fix your problem?
Postby rafadc » Wed May 04, 2011 11:59 am
With that change it's working..... strange...
Maybe wifi is falling and it's trying to revert to 3g or something like that?
rafadc
Re: Warning: No network available when downloading or strami
Postby talynone » Mon Oct 10, 2011 10:15 pm
I had the same error, except I wanted to stream over 3G and I do have a license. Since this is the only Subsonic forum post that shows up when you google "subsonic" and "No network available" I thought I'd post the solution I found here:
Double check "Wi-Fi streaming only" is unchecked in the Android app.
Start the subsonic app at the main page, press the menu button on your phone and press the "Settings" menu item. In the "Network" section make sure "Wi-Fi streaming only" is unchecked. Go back to the music item and try again.
talynone
