Some files wont play
Postby larza » Tue May 03, 2011 2:26 pm
I´ve tried to find any similar posts but haven´t managed.
I have several mp3 files that refuses to play. The player buffers the file, but when hitting play the only thing that happends is that the button goes back to play symbol (showing paus for half a second)..
No error in the log, only showing:
PlaylistInputStream admin listening to ...
The files not working seems to be 320 kb/s, but I have other 320 kb files that do work.
Any ideas? :)
larza
Postby Exrace » Wed May 04, 2011 2:08 am
What do you have in your encoding settings?
Did you make any changes from the defaults?
Exrace
Postby larza » Wed May 04, 2011 5:26 am
Exrace wrote:What do you have in your encoding settings?
No changes in theese settings. Baiscly drilled it down to 2 albums, I´ll use the CD and make a new version.. Strange though..
But what I now don´t get when playing around with the settings, when I set down the max bitrate i cannot play files exceding this limit, seems like lame compress is not working....
Lame is installed but get this error log:
[5/4/11 8:24:00 AM EEST] INFO PlaylistInputStream admin listening to "1995 Foo Fighters/01 This Is a Call.mp3"
[5/4/11 8:24:00 AM EEST] DEBUG TranscodeInputStream Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-loglevel] [error] [-v] [0] [-i] [/media/server/Music/Artist/Foo Fighters/1995 Foo Fighters/01 This Is a Call.mp3] [-f] [mp3] [-acodec] [libmp3lame] [-ar] [44100] [-ab] [320k] [-ac] [2] [-map_meta_data] [0:0] [-]
[5/4/11 8:24:00 AM EEST] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) FFmpeg version 0.6.2-4:0.6.2-1ubuntu1, Copyright (c) 2000-2010 the Libav developers
[5/4/11 8:24:00 AM EEST] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) built on Mar 22 2011 15:35:22 with gcc 4.5.2
[5/4/11 8:24:00 AM EEST] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) configuration: --extra-version=4:0.6.2-1ubuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --enable-shared --disable-static
[5/4/11 8:24:00 AM EEST] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) WARNING: library configuration mismatch
[5/4/11 8:24:00 AM EEST] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavutil configuration: --extra-version=4:0.6.2-1ubuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
[5/4/11 8:24:00 AM EEST] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavcodec configuration: --extra-version=4:0.6.2-1ubuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
[5/4/11 8:24:00 AM EEST] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavformat configuration: --extra-version=4:0.6.2-1ubuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
[5/4/11 8:24:00 AM EEST] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavdevice configuration: --extra-version=4:0.6.2-1ubuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
[5/4/11 8:24:00 AM EEST] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavfilter configuration: --extra-version=4:0.6.2-1ubuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
[5/4/11 8:24:00 AM EEST] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libswscale configuration: --extra-version=4:0.6.2-1ubuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
[5/4/11 8:24:00 AM EEST] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libpostproc configuration: --extra-version=4:0.6.2-1ubuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
[5/4/11 8:24:00 AM EEST] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavutil 50.15. 1 / 50.15. 1
[5/4/11 8:24:00 AM EEST] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavcodec 52.72. 2 / 52.72. 2
[5/4/11 8:24:00 AM EEST] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavformat 52.64. 2 / 52.64. 2
[5/4/11 8:24:00 AM EEST] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavdevice 52. 2. 0 / 52. 2. 0
[5/4/11 8:24:00 AM EEST] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavfilter 1.19. 0 / 1.19. 0
[5/4/11 8:24:00 AM EEST] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libswscale 0.11. 0 / 0.11. 0
[5/4/11 8:24:00 AM EEST] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libpostproc 51. 2. 0 / 51. 2. 0
[5/4/11 8:24:00 AM EEST] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Unknown encoder 'libmp3lame'
The complete log is saved in /var/subsonic/subsonic.log.
larza
