ConnectTimeoutException- appreciate any help
Postby alandub » Mon May 09, 2011 12:27 am
Hi All,
Hope to ask for some help on an issue that I cant get my head around fixing- mostly due to being a newb with networking/port-forwarding stuff. I'm on Kubuntu Lucid and have installed ok, in the control panel I get the message that I am successfully forwarding to port 4040
However I get the following error message regarding the easy to remember address to access the server
<name>.subsonic.org is registered, but could not connect to it. (ConnectTimeoutException)
also I checked out http://www.yougetsignal.com/tools/open-ports/ and scanned all common ports and it seems none are open
Any advice would be greatly appreciated- thanks for your time & help! :D
alandub
Postby GJ51 » Mon May 09, 2011 1:38 am
I've just been doing some network reconfiguration and I made some changes and a fresh SS install. I got tthe same errore message when I input my Subsonic.org servername, but it still took and works fine. Sindre recently mentioned that he moved the redirection service to a new server, so it may just be a minor glitch he hasn't resolved yet. Best I can tell though, it has no adverse effect.
Postby alandub » Mon May 09, 2011 8:07 pm
GJ51 wrote:I've just been doing some network reconfiguration and I made some changes and a fresh SS install. I got tthe same errore message when I input my Subsonic.org servername, but it still took and works fine. Sindre recently mentioned that he moved the redirection service to a new server, so it may just be a minor glitch he hasn't resolved yet. Best I can tell though, it has no adverse effect.
hey Gary
Good news it's working now! seems that error message is a bit of a red herring
Now that Ive got it going any tips on tweaking? :wink:
thanks again
alandub
Postby GJ51 » Mon May 09, 2011 8:27 pm
The best advice I can give you is to keep the file structure simple and integrate each new feature one at a time. Read ALL the menus and get a good feel for the interface. If you get into video, try to preformat into mp4 or flv to avoid transcoding which takes cpu load. Most of all, have fun. SS is highly configurable and can be tweaked to your likes and dislikes. It's very flexible. Finally, I think it looks best when you use Chrome for the front end interface.
Postby corybucher » Mon May 30, 2011 12:36 am
I've been having the same error when I am outside my wifi connection. It tells me that the router has been successfully configured and port forwarded to port 4040. Do I need to try and create an additional port forward or is this also just a kink in the system? Any advice would be greatly appreciated and also I am also a complete novice to port forwarding and any kind of network configuring. Thanks in advanced.
corybucher
Postby GJ51 » Mon May 30, 2011 3:48 am
http://www.java.com/en/download/manual.jsp If you have SS installed, uninstall it and delete the Subsonic directory (Windows).
Disable any DHCP services in any VOIP equipment or other additional routers you have. Only ONE router/device per network should handle DHCP assignments.
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080 - 440, 8081 - 441, etc. Skip 8083 - 443 to avoid conflicts with WHS.
Users browsing this forum: Google [Bot] and 55 guests
