Ubuntu Mvaerick 10.10 subsonic 4.4 dpkg install error
Postby speed32219 » Fri May 13, 2011 5:08 am
Here is the error:
Unpacking subsonic (from subsonic-4.4.deb) ...
dpkg-deb (subprocess): short read on buffer copy for failed to write to pipe in copy
dpkg-deb: subprocess paste returned error exit status 2
dpkg: error processing subsonic-4.4.deb (--install):
short read on buffer copy for backend dpkg-deb during `./usr/share/subsonic/subsonic-booter-jar-with-dependencies.jar'
Removing any system startup links for /etc/init.d/subsonic ...
Processing triggers for ureadahead ...
Errors were encountered while processing:
subsonic-4.4.deb
I purged and removed openjdk-6-jre and then re-installed it. Had some half installed messages in dpkg.log. Re-booted and everthing looked good so ran sudo dpkg -i subsonic-4.4.deb again with same errors being displayed as above.
Thank you for any suggestions.
speed32219
Postby jaja » Fri May 13, 2011 7:04 am
see your command for installation
regards
jaja
jaja
Postby speed32219 » Sat May 14, 2011 4:10 pm
Fixed:
Re-loaded Java, rebooted and ran installer.
speed32219
Users browsing this forum: No registered users and 44 guests
