Reset my trial?
Reset my trial?
Postby mackg » Fri May 13, 2011 6:20 am
I tried subsonic a few months ago and couldnt get it to work because the router i had. recently picked up a new router and would like to try subsonic. but my trial period is over is there anyway i could get my trial period restarted so i can try before i decide to buy just want to make sure i can set this up on my new router
mackg
Postby Minime » Fri May 13, 2011 12:47 pm
You can install SS again and get a new trial period.
Best Regards
Minime,
Subsonic 4.6 | Ubuntu 10.04 LTS inside a VMWare host
Galaxy SII with ICS 4.0.1 & Android App v3.0 Combo
XBMC Dharma with t0mm0-xbmc-addons
+ A few custom Mods
Minime
Postby burjast » Fri May 13, 2011 12:55 pm
sounds like bull crap? :) You can install and use subsonic without trial limitations -> "just want to make sure i can set this up on my new router"
payment is only to allow use of API and remote listening -> use of other programs which interact with subsonic..
I just know.
burjast
Postby Minime » Fri May 13, 2011 1:26 pm
burjast wrote:sounds like bull crap? :) You can install and use subsonic without trial limitations -> "just want to make sure i can set this up on my new router"
It taked maximum 2 min to install SS. It makes more sense to me getting the latest ver. of SS and doing a new fresh install than try and troubleshoot a ver. that is at least a few months old and never proven to work.
Dont over complicate things or jump to conclutions. We dont even know if this user has a need that requires a license or not. Getting a fresh start is never a bad idea.
Best Regards
Minime,
+ A few custom Mods
Minime
Postby mackg » Fri May 13, 2011 9:37 pm
I Did do a fresh install before i posted this topic, the fresh install said my trial period was over. i guess ill try it again
mackg
Postby Minime » Fri May 13, 2011 10:01 pm
Sorry Mate, i should have been more specific with my earlier instructions. Please delete your existing SS servers directories before installing a new one. Installing over an existing system will overwrite the package, but retain all data & settings.
Not sure what OS you are running but, if you are on windows delete C:\Subsonic
If you are on linux, here are the directories SS creates:
/etc/default/subsonic
/var/subsonic/db/
/var/subsonic/playlists/
/var/subsonic/subsonic.properties
Good luck
Best Regards
Minime,
+ A few custom Mods
Minime
Postby mackg » Fri May 13, 2011 11:49 pm
yeah, i deleted that directory. i have it figured out now. thanks for the help. now i just have to figure out how to get this up and running on the mobile end
mackg
Users browsing this forum: No registered users and 59 guests
