Unable to access my music server
Postby doomius » Fri May 13, 2011 2:19 pm
I noticed yesterday that the iSub app for my iPhone would not play any files.
I can view artist folders but when I click on the artist name, no songs are displayed.
Today I tried to check my personal server (http://username.subsonic.org) and I get the following message:
"HTTP ERROR: 404
NOT_FOUND
RequestURI=/
Powered by jetty://"
an IP address is also displayed in the address field.
Not sure what is wrong but it looks like my server is unavailable for some reason, I haven't changed any setting since my original configuration.
Any help will be appreciated.
doomius
Postby GJ51 » Fri May 13, 2011 2:30 pm
http://www.java.com/en/download/manual.jsp If you have SS installed, uninstall it and delete the Subsonic directory (Windows).
Disable any DHCP services in any VOIP equipment or other additional routers you have. Only ONE router/device per network should handle DHCP assignments.
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080 - 440, 8081 - 441, etc. Skip 8083 - 443 to avoid conflicts with WHS.
