"a network error occurred"
Postby samuelaviv » Mon May 16, 2011 6:01 pm
hi..
please.. someone.. im going nuts here... "a network error occurred", thats what it says when i try to connect via my android... ive tried everything ! reinstalled java and SS, i have static ip, port forward works (username.subsonic.com is forwarded correctly to my router via a port i selcted , not 80 ,)....please help...
samuelaviv
Postby GJ51 » Mon May 16, 2011 6:27 pm
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080 - 440, 8081 - 441, etc. Skip 8083 - 443 to avoid conflicts with WHS.
Postby samuelaviv » Mon May 16, 2011 7:01 pm
hello again.. thanks for replying rapidly..
i think i am forwarding my ports correctly because there are a few other things working with port forwarding on my network. my internal ip is static as explained on http://www.portforward.com and i use that as well with other stuff with no hitch. when i check my forwarded port (not 8080,8081,80 or any of the isp "used" ports) at http://www.canyouseeme.org/ it says all good and " Automatically configure your router to allow incoming connections to Subsonic (using UPnP or NAT-PMP port forwarding) " was already unchecked and it displays a message that my router is found then it goes on to say "port forwarding disabled", and that is the puzzling part because by any other indication it is enabled and the port is open. another thing, you say to check the settings with the external ip and see if it connects.. ive tried using the external ip number that http://www.canyouseeme.org/ told me i had with the :port# and that didnt work, but trying fixed internal ip :p# opens the SS control panel in my browser ..does that mean the static ip is good and set ? i have read and followed all the relevant guides to port forwarding my router on http://www.portforward.com before and during the SS setup, and up until now it worked quite successfully but this time im baffled. i hope you can help.
thanks again.
samuelaviv
Postby GJ51 » Tue May 17, 2011 1:54 pm
Something is definitely wrong if the internal ip:port# is opening the SS Control Panel and not the SS logon page. On the host computer, right click the green SS tray icon and open the SS Control Panel. What port is assigned for http? Disable the SSL port until you get http access established.
Also check that you can open SS local instance from the tray icon and that it runs properly.
Just because a port is open, does not necessaarily mean that it is being sent to the right address. I've never used port forward.com, so I don't know what it is doing, but I do know that if you have SS set to operate on an specific port and it is properly forwarded to the host computer's internal ip, and SS is configured to listen to that port, everything will work.
You say that Canyouseeme.org says it's all good. Plesase be more specific. Does it report that the http port you have set SS to is open? Is it possible that you have that port in use by something other than SS and there is a rtouting conflict?
If you have no other programms running on 8085, I'd suggest trying to set up SS on 8085. I recently discovered that WHS 2011 uses 8080 for internal use, so that's one that we may want to start staying away from. AS always, I advise that no one should use 80, or 443.
