Installed but not located....
Postby knowledgeisback » Sat May 21, 2011 4:31 pm
So I installed subsonic on Ubuntu 10.10 thanks to the .deb package which made it easy (or so I thought), but when I went to go use subsonic it was nowhere to be found. I checked the software center again to verify that it was installed and it was. However it also said that the program took up 0 bytes. (i.e. it wasn't really there). So i tried to install it again, and the same issue occurred. Am I doing something wrong?
knowledgeisback
Postby Kirk » Mon Jun 06, 2011 5:23 am
Have you tried going to http://localhost:4040/ on the computer in Firefox?
Also, Subsonic should be located in /var/subsonic/ on your filesystem.
-Kirk
Kirk
