Trouble connecting from outside of my home network
Postby jl55378008 » Mon May 30, 2011 2:32 pm
I'm unable to connect to my subsonic from outside of my home network. I've tried using my [user].subsonic.org alias, as well as my IP address, and neither work.
I can connect just fine from any PC on my home network.
Somehow, I'm able to connect using the z-Subsonic iPhone app (via [user].subsonic.org), but not from a PC browser. Connecting from z-Sub is very slow, though.
When I ping [user].subsonic.org, I get the IP 66.49.215.227, which is the Subsonic website. Is that right?
I have a pretty large library (~600GB music, 200GB movies). Would that cause a timeout at the login page?
My setup:
W7 64-bit
v4.4 (build 2172)
TP-Link WR541G Router
jl55378008
Postby GJ51 » Mon May 30, 2011 9:34 pm
First read: http://monroeworld.com/android/subsonic/ This is the Windows tutorial but most of the concepts apply to any setup. Specific setup instructions for other Operating Systems are available in the Tutorials section. http://forum.subsonic.org/forum/viewforum.php?f=6 and on the Subsonic website at http://www.subsonic.org/pages/installation.jsp
Never use port 80 - ISP's often use it or block it. 8080,8081, work fine. 808X Always works. I've seen others use different port numbers that have caused install failure.
http://www.java.com/en/download/faq/java_win64bit.xml
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080, 8081, etc.
Test your setup by entering your external IP:port# to see if it connects. e.g. http://108.17.27.224:8092/ If it works, you're good to go.
Users browsing this forum: Google [Bot] and 17 guests
