Where is the control panel? Yes, I am new.
Postby krukru » Wed Jun 01, 2011 7:30 pm
Hi, just trying to set a new level of noobness here:
Problem: Cannot find subsonic control panel
System: Linux Ubuntu
Steps taken: installed the subsonic package, it gives me
Package 'subsonic-4.4.deb.' was installed
Now i want to open it but theres nothing like a systray icon. I am absolutely new to linux and might have hidden the whole systray or do i need to do sth else beforehand?
krukru
Postby krukru » Fri Jun 03, 2011 8:10 am
Ok, so i dont know if youre all just chuckling away in your admin-thrones or if i just posed the question wrong. Thing is, i need to change the ports subsonic uses and i dont know how to do that others than via the panel (which hides in linux wonderland, probably sipping a chilled chapirinha at the pool next to my slightly fucked up xbox NAT).
any ideas?
krukru
Postby henning » Fri Jun 03, 2011 8:58 am
1. did you start subsonic already ?
In the terminal (konsole) as root: ./subsonic.sh
In the right directory :-)
2. by default it's using port 4040
So in your browser : http://localhost:4040 should give you the subsonic screen
If you need anoter port you need to edit subsonic.sh in the top part where you can read the various settings.
Hope it helps
Henning
henning
Postby Kirk » Mon Jun 06, 2011 4:46 am
henning wrote:If you need anoter port you need to edit subsonic.sh in the top part where you can read the various settings.
Incorrect sir... he installed from the debian package, so there's no sh. He needs to edit /var/subsonic/subsonic.properties
Kirk
Postby krukru » Mon Jun 06, 2011 8:49 pm
Kirk wrote:He needs to edit /var/subsonic/subsonic.properties
Thats what i was looking for, thanks. But..
I did edit that, set the port to 8081, restarted the router, restarted subsonic, but its still reachable only at localhost:4040. Do i need to change sth else for the port to change?
Also I unchecked "automatic port forwarding" in settings and saved.
krukru
Users browsing this forum: Google [Bot] and 50 guests
