Cannot play Formats other than FLAC
Postby Paws » Thu Jun 02, 2011 1:04 am
Hey, ive had subsonic for quite a while now, been using it on windows for a few months and then decided to switch over to Debian (Lenny).
First installation there was no "lame" package so i installed twolame/toolame. Worked. Then i found out i couldn't play FLAC files, only MP3 files.
Problem Description: Cant play any files except for MP3 and Movies
Troubleshooting Steps: Using flac directly to transcode and then using lame.
Subsonic Version: 4.4 (build 2169) – February 6, 2011
Server Version: jetty-6.1.x, java 1.6.0_18, Linux (36.8 MB / 38.3 MB)
Hardware Platform: Linux Debian Lenny
Java Memory Limit: Not sure, enough i guess.
Problem Filename: All files other than MP3 and Movies
Output from ffmpeg -i: (If you open a command prompt and type 'ffmpeg -i <filename>' what is the output? Ideally put this in a "code" block)
Last ten log file lines: (The last ten or so lines copied and pasted from the About screen in the Subsonic Web Interface. Ideally these will be in a CODE block as well.)
I tried using flac directly and then lame, but alas no worky.
[2011-06-02 02:36:46,002] DEBUG AudioScrobblerService - Successfully registered now playing for song 'We Can`t Fly' for user at Last.fm.
[2011-06-02 02:36:48,561] INFO PlaylistInputStream - admin listening to "We Can't Fly (FLAC)/03 - Superstar.flac"
[2011-06-02 02:36:48,565] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/flac] [-c] [-s] [-d] [/nom/user/Music/Aeroplane/We Can't Fly (FLAC)/03 - Superstar.flac]
[2011-06-02 02:36:48,595] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/lame] [-b] [128] [--tt] [Superstar] [--ta] [Aeroplane] [--tl] [We Can't Fly] [-S] [--resample] [44.1] [-] [-]
[2011-06-02 02:36:48,625] WARN TranscodingService - Failed to transcode /nom/tala0014/Music/Aeroplane/We Can't Fly (FLAC)/03 - Superstar.flac. Using original.
java.io.IOException: Cannot run program "/var/subsonic/transcode/lame": java.io.IOException: error=2, No such file or directory
   at java.lang.ProcessBuilder.start(ProcessBuilder.java:475)
   at net.sourceforge.subsonic.io.TranscodeInputStream.<init>(TranscodeInputStream.java:61)
   at net.sourceforge.subsonic.service.TranscodingService.createTranscodeInputStream(TranscodingService.java:358)
   at net.sourceforge.subsonic.service.TranscodingService.getTranscodedInputStream(TranscodingService.java:257)
   at net.sourceforge.subsonic.service.TranscodingService.getTranscodedInputStream(TranscodingService.java:212)
   at net.sourceforge.subsonic.io.PlaylistInputStream.prepare(PlaylistInputStream.java:130)
   at net.sourceforge.subsonic.io.PlaylistInputStream.read(PlaylistInputStream.java:94)
   at net.sourceforge.subsonic.io.PlaylistInputStream.read(PlaylistInputStream.java:86)
   at net.sourceforge.subsonic.controller.StreamController.handleRequest(StreamController.java:202)
Caused by: java.io.IOException: java.io.IOException: error=2, No such file or directory
   at java.lang.UNIXProcess.<init>(UNIXProcess.java:164)
   at java.lang.ProcessImpl.start(ProcessImpl.java:81)
   at java.lang.ProcessBuilder.start(ProcessBuilder.java:468)
   ... 60 more
FFmpeg version 0.6.2-4:0.6.2-3, Copyright (c) 2000-2010 the Libav developers
  built on Apr 30 2011 10:12:41 with gcc 4.5.3
  configuration: --extra-version=4:0.6.2-3 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-libopenjpeg --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libfaad --enable-libdirac --enable-libfaad --enable-librtmp --enable-libdc1394 --enable-shared --disable-static
  libavutil   configuration: --extra-version=4:0.6.2-3 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-libopenjpeg --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libfaad --enable-libdirac --enable-libfaad --enable-librtmp --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libavcodec  configuration: --extra-version=4:0.6.2-3 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-libopenjpeg --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libfaad --enable-libdirac --enable-libfaad --enable-librtmp --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libavformat configuration: --extra-version=4:0.6.2-3 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-libopenjpeg --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libfaad --enable-libdirac --enable-libfaad --enable-librtmp --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libavdevice configuration: --extra-version=4:0.6.2-3 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-libopenjpeg --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libfaad --enable-libdirac --enable-libfaad --enable-librtmp --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libavfilter configuration: --extra-version=4:0.6.2-3 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-libopenjpeg --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libfaad --enable-libdirac --enable-libfaad --enable-librtmp --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libswscale  configuration: --extra-version=4:0.6.2-3 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-libopenjpeg --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libfaad --enable-libdirac --enable-libfaad --enable-librtmp --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libpostproc configuration: --extra-version=4:0.6.2-3 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-libopenjpeg --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libfaad --enable-libdirac --enable-libfaad --enable-librtmp --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libavutil     50.15. 1 / 50.15. 1
  libavcodec    52.72. 2 / 52.72. 2
  libavformat   52.64. 2 / 52.64. 2
  libavdevice   52. 2. 0 / 52. 2. 0
  libavfilter    1.19. 0 /  1.19. 0
  libswscale     0.11. 0 /  0.11. 0
  libpostproc   51. 2. 0 / 51. 2. 0
Input #0, flac, from '/nom/User/Music/Aeroplane/We Can't Fly (FLAC)/01 - Mountains of Moscow.flac':
  Metadata:
    TITLE           : Mountains of Moscow
    ARTIST          : Aeroplane
    ALBUM           : We Can`t Fly
    GENRE           : Dance & House
    COMPOSER        : Vito De Luca & Stephen Fasano
    TRACKNUMBER     : 1
    TRACKTOTAL      : 12
    TOTALTRACKS     : 12
    DISCNUMBER      : 1
    DISCTOTAL       : 1
    TOTALDISCS      : 1
    DATE            : 2010
    ISRC            : BEN581000105
  Duration: 00:02:56.90, bitrate: 899 kb/s
    Stream #0.0: Audio: flac, 44100 Hz, 2 channels, s16
Paws
Postby yourlord » Thu Jun 02, 2011 5:32 pm
you don't have lame in /var/subsonic/transcode
yourlord
Postby Paws » Fri Jun 03, 2011 11:22 am
but i did ;) it was just linked to a faulty or corrupt lame in /usr/bin/lame so i changed the link to /usr/local/bin/lame then it worked perfectly
Paws
