[SOLVED] yourname.subsonic.org not working after...
Postby cancerous86 » Sat Jun 04, 2011 9:36 pm
As mentioned in the title, I recently switched linux distros as well as changed residences. I went from Ubuntu 11.04 to Fedora 15 and reinstalled Subsonic. Now, when I try to put in my custom URL, it says it's already in use.
I assume your server no longer recognizes my computer after the distro change/move. I have tested my port forwarding through portforward.com as well as going to my external IP+forwarded port in my web browser.
Would it be possible to "reset" this custom URL so I can utilize it again?
http://i.imgur.com/Bjbmg.png
Thank you!
cancerous86
Postby alphawave7 » Sun Jun 05, 2011 2:55 am
This exists due to the donation/reg code NOT being entered into the new server. Fetch your code from the original email, and paste it in..that should clear it up.
Postby cancerous86 » Sun Jun 05, 2011 2:22 pm
alphawave7 wrote:This exists due to the donation/reg code NOT being entered into the new server. Fetch your code from the original email, and paste it in..that should clear it up.
Gah! So simple. Thank you for the advice. I should have tried this before.
Thanks again,
C86
cancerous86
Users browsing this forum: Google [Bot] and 17 guests
