WMA files do not play after upgrading to 4.4
Postby hormelspam » Tue Jun 07, 2011 12:16 pm
Upgraded to 4.4 now none of my WMA files play. My MPS files still work.
Any help would be greatly appreciated.
Here's my logs looks like a problem with the transcoding.
[6/7/11 8:13:21 AM EDT] INFO PlaylistInputStream admin listening to "Whatever's Cool With Me\02 Sideways.wma"
[6/7/11 8:13:21 AM EDT] DEBUG TranscodeInputStream Starting transcoder: [c:\subsonic\transcode\wmadec] [\\Ts-tgl7da\Music\Win_Music\Dinosaur Jr\Whatever's Cool With Me\02 Sideways.wma]
[6/7/11 8:13:21 AM EDT] DEBUG TranscodeInputStream Starting transcoder: [c:\subsonic\transcode\lame] [-b] [128] [-x] [-] [-]
[6/7/11 8:13:21 AM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\lame) Warning: unsupported audio format
Here's my trans coder
wma > mp3 Step 1 wmadec %s Step 2 lame -b %b -x - -
hormelspam
Postby GJ51 » Tue Jun 07, 2011 3:19 pm
Mine play with the default settings:
ffmpeg -i %s -v 0 -f wav -
lame -b %b --tt %t --ta %a --tl %l -S --resample 44.1 - -
Postby Kirk » Tue Jun 07, 2011 4:28 pm
When you upgraded, maybe it removed the contents of the transcoder folder... is wmadec still installed, where you put it originally to make it work?
I suspect GJ51's method will solve your problem, regardless.
-Kirk
Kirk
Postby hormelspam » Tue Jun 07, 2011 7:01 pm
The transcoder appears to be their.
c:\subsonic\transcode\wmadec.exe
This worked before I upgraded. Also mp3's work fine.
I tried using GJ51's settings but still no luck. The settings that I sent in my first post were the subsonic defaults, I never changed them. Do you have to restart SubSonic for thr transcoder change to take effect?
Thanks again for the help.
Scott
hormelspam
Postby hormelspam » Tue Jun 07, 2011 7:15 pm
Sorry for the multiple posts.
GJ51's suggestion worked after a restart of SubSonic.
Thanks GJ51 and Kirk for the support.
hormelspam
Re: WMA files do not play after upgrading to 4.4
Postby cbstxbill » Wed Sep 12, 2012 8:55 pm
I have the following error when attempting to play wma
Duration: 00:13:14.99, start: 0.000000, bitrate: 655 kb/s
[9/12/12 4:50:20 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream #0.0: Audio: c[1][0][0] / 0x0163, 44100 Hz, 2 channels, 1152 kb/s
[9/12/12 4:50:20 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Incompatible sample format '(null)' for codec 'libmp3lame', auto-selecting format 's16'
[9/12/12 4:50:20 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Output #0, mp3, to 'pipe:':
[9/12/12 4:50:20 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream #0.0: Audio: libmp3lame, 44100 Hz, 2 channels, s16, 128 kb/s
[9/12/12 4:50:20 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream mapping:
[9/12/12 4:50:20 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream #0.0 -> #0.0
[9/12/12 4:50:20 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Decoder (codec id 86057) not found for input stream #0.0
[9/12/12 4:50:56 PM EDT] INFO TranscodingDao
cbstxbill
Postby GJ51 » Wed Sep 12, 2012 9:03 pm
These posts are a bit dated. If you're using the advice here, then you'll have to put lame.exe into the transcode folder. WMA vbr files can be a bit tricky to get working right. The more details about your platform and what setup your using to do the transcoding, the more likely someone can contribute a helpful answer for you.
