[Solved] Changing the width of the Artist column
Postby Citrixfr » Tue Jun 07, 2011 9:54 pm
I wonder how to enlarge the list on the left. I'd like to see the entire names.
I tried to find out the CSS but... I didn't -_-
Thanks for help :)
Citrixfr
Postby Kirk » Wed Jun 08, 2011 2:29 pm
I don't suspect that will be extremely easy to do. You will probably need to modify the source code inside the Jar file or something in order to make that type of change to Subsonic.
-Kirk
Kirk
Postby Citrixfr » Wed Jun 08, 2011 2:50 pm
I'll keep looking, there must be a way. The hardest is to find out the correct file to edit :(
Citrixfr
Postby supra92 » Wed Jun 08, 2011 6:35 pm
Hi Citrixfr,
Changing the width of the Artist column on the left does indeed require modifying the JSP code, but thankfully it's not that involved a process.
First, stop Subsonic.
The file you'll want to edit is: $SUBSONIC_HOME/WEB-INF/jsp/index.jsp
Your Subsonic home will vary depending on your OS and installation type (standalone jetty, tomcat WAR, etc.) My tomcat6-based Subsonic home is located at: /usr/share/tomcat6/webapps/subsonic/
Edit the index.jsp file and look for the following line:
<frameset cols="15%,85%" border="0" framespacing="0" frameborder="0">
The 15% is the width of the left artist column, while the 85% is the width of the main area -- together they should add up to 100%. You can modify those however you want, ie changing them to 30%, 70% for example. You could also go with a fixed-width if that is more to your liking, by specifying a pixel width for the artist column and then * for the main column (so that it takes up whatever else is left).
Start Subsonic back up, and you should be off to the races.
Regards,
Supra92
supra92
Postby Citrixfr » Wed Jun 08, 2011 6:40 pm
Hi supra92,
Just did it and it works!! woot!
Thanks a lot my Subsonic looks really better now ;)
Citrixfr
Citrixfr
Postby BluesBoy » Mon Jun 27, 2011 3:35 am
Supra Thanks so much for your help with this. Worked great!
BluesBoy
BluesBoy
