Trouble getting this to work from phone
Postby sperrystreet » Tue Jun 07, 2011 11:35 pm
I have successfully installed Subsonic on a local computer - I can run it from the local computer, play music using the interface, and I can access subsonic with the name I setup *.subsonic.org from this same local computer. But I cannot access this from another computer or from my phone.
Subsonic is installed on a Win Vista machine.
Droid X Verizon phone.
Belkin router (F5D8233-4-v1).
I have the port forwarding configured for 8080 and 4040 (tcp and udp). The address they are forwarding to has a "forever" lease for the IP of the computer I've installed subsonic on (It does not seem there is a way to assign only a static ip to that local computer with this belkin router -- it allows a "forever' lease however so I know it does not change).
When I open subsonic by going to *.subsonic.org
I login. go to settings>network
Automatic configure is unchecked...but there is a message that says "Status: port forwarding disabled"
I went to the Portforwarding site and followed the directions for my specific router but this still does not work.
I've uninstalled and restarted and followed the guide here, but I must not be configuring something with the router exactly right.
Again -- it does not look like there is a way to configure the router and assign a specific IP to that computer. Although I have never seen that IP change since I setup the network. I have DHCP on, it assigns the address 192.168.2.3 to the computer where subsonic is installed and leaves it there. If I turn off DHCP there is no option for assigning a static ip to a device.
Any help would be greatly appreciated.
sperrystreet
Postby GJ51 » Wed Jun 08, 2011 12:03 am
You need to reread the setup information as you don't need 8080 and 4040 open and you don't need UDP open.
http://www.java.com/en/download/manual.jsp If you have SS installed, uninstall it and delete the Subsonic directory (Windows).
Disable any DHCP services in any VOIP equipment or other additional routers you have. Only ONE router/device per network should handle DHCP assignments.
First read: http://monroeworld.com/android/subsonic/ This is the Windows tutorial but most of the concepts apply to any setup. Specific setup instructions for other Operating Systems are available in the Tutorials section. http://forum.subsonic.org/forum/viewforum.php?f=6 and on the Subsonic website at http://www.subsonic.org/pages/installation.jsp
Never use port 80 - ISP's often use it or block it. 8080,8081, work fine. 808X Always works. I've seen others use different port numbers that have caused install failure.
http://www.java.com/en/download/faq/java_win64bit.xml
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080, 8081, etc.
Test your setup by entering your external IP:port# to see if it connects. e.g. http://108.17.27.224:8092/ If it works, you're good to go.
Postby sperrystreet » Wed Jun 08, 2011 1:22 am
The documentation provided at http://monroeworld.com/android/subsonic/
Under port forwarding... says
3. Create a new forwarding entry saying that for port 8080 (or whatever you chose), send all TCP and UDP traffic to 192.168.0.125 (or whatever you chose). Be sure to send BOTH types of traffic - not just TCP or UDP.
I removed the VOIP phone connected to the computer. The Java is the current version.
I still can't get this to work. Any ideas are appreciated.
sperrystreet
Postby GJ51 » Wed Jun 08, 2011 2:45 am
You don't need to forward UDP, it probably doesn't hurt, but it isn't required.
"Go to http://www.canyouseeme.org/ enter your SS port number and click the Check box to be sure the Subsonic port is open."
What did you get when you followed this instruction?
Postby sperrystreet » Wed Jun 08, 2011 2:21 pm
Error: I could not see your service on 97.81.xx.xxx on port (8080)
Reason: Connection refused
sperrystreet
Postby GJ51 » Wed Jun 08, 2011 2:45 pm
Assuming that you can connect to SS internally on the host pc, then this means that your router is not set up correctly. Reread the instructions for port forwarding on your router. This is the part that everyone has trouble with.
You must forward any incoming traffic on port 8080 to the PC that is hosting SS at it's internal ip address. 8080 > 192.168.2.3
192.168.2.3 ??? Not impossible, but most home routers use 192.168.1.x
Check all your numbers carefully.
Postby sperrystreet » Wed Jun 08, 2011 3:01 pm
That's what is strange I can connect to SS from the local computer. If open Firefox and enter http://*.subsonic.org ... i get the login interface, i login and use SS.
From my phone or another computer I put in that same address and it won't work.
192.168.2.1 is the router (yes weird...but that is correct)
And under the "virtual server" section of the router configuration I have the port 8080 forwarding to 192.168.2.3.
Here's the configuration set in the router (under the virtual server section)
Enabled: (checked)
Description: Subsonic
Inbound port: 8080
Type: TCP/UDP (selected)
Private IP address: 192.168.2.3
Private port: 8080
This is what Belkin says to do and the directions from the PortForwarding site say to do.
Could the "inbound port" designation be the problem??
[/img]
sperrystreet
Postby GJ51 » Wed Jun 08, 2011 3:25 pm
Can you access the login page from inside the network on another system, such as your phone on local wifi?
Postby GJ51 » Wed Jun 08, 2011 3:27 pm
sperrystreet wrote:That's what is strange I can connect to SS from the local computer. If open Firefox and enter http://*.subsonic.org ... i get the login interface, i login and use SS.
Enabled: (checked)
Inbound port: 8080
Private port: 8080
[/img]
Please try changing Type: TCP/UDP to TCP only.
Postby sperrystreet » Wed Jun 08, 2011 3:38 pm
Ah -- it was the F-secure antivirus on the local computer. I turned it off and now I can access SS.
Sorry that I did not think of that earlier. I appreciate your help.
sperrystreet
Postby GJ51 » Wed Jun 08, 2011 3:46 pm
That makes sense. If the router is ok then the only other obstacle is a firewall on the local host. That's why i asked you to test connectivity from another device inside the loacal network.
Glad you got it working. Enjoy SS. :D
