Can't Install License
Postby Dirk Funk » Wed Jun 08, 2011 9:52 pm
I'm sure this has to have come up before but I'm having a hard time finding the answer on here. My situation is that I donated and did receive my license in the mail to fully activate subsonic.
The problem is that the directions on here say to install the license by going to your subsonic web interface and following the donation link on the top right. When I go to do this I get taken to a page that says my "trial is expired" and directs me to donate with no place to enter the license.
Is this the only way to activate this? If so, how do I get around this screen so I can apply my license?
Thanks in advance.
Dirk Funk
Postby Citrixfr » Thu Jun 09, 2011 1:38 am
Searching the forums it seems you just have to reinstall SS and you'd be able to go with it.
http://forum.subsonic.org/forum/viewtop ... ial+expire
Citrixfr
Citrixfr
Postby Kirk » Thu Jun 09, 2011 3:47 pm
The other thing you might be able to do, is edit your "subsonic.properties" and add the key code in there - as that's where it's stored. Then, if you restart your Subsonic server, I think it will correctly apply the new license.
A reinstall should work for sure, though.
Kirk
