pcs800 wrote:Ok I did some reading and figured out that I need to set the players max bitrate, but that brings up another question. Why are there so many players? I have 19 users and 91 players! What's up with that? WOuldn't there be one player per user? And a second one if they log in with a phone or something?
pcs800 wrote:I would love to wipe out all the extra players, but doesn't that require you to watch the list and set the bit rate as they are created? Man what an annoyance, everything else about subsonic rocks but the creation of players is just goofy.
I Also noticed that once in a while it will say "you need flash to play subsonic" or something of the sort, and shows no player. But if I switch players at the user level it works fine.
That confuses less technical users and causes me phone calls and emails.
Can we suggest that each user gets ONE player for web (any and all browsers) and one for mobile devices? I'd donate again for that.
pcs800 wrote:Nope, it happens to me fairly often, I use 32 bit avant browser which runs on IE. I have seen it happen to other users as well.
A player per user is the answer.
Users browsing this forum: Google [Bot] and 17 guests
