Port issues
Port issues
Postby sbnic » Mon Jun 13, 2011 3:00 pm
I just installed subsonic on my win 7 ultimate machine but i am facing problems. I tried many ports but none of them seem to work. i tried 80,880,881, 8080, 8081...
Every time i change ports, i press Ctrl+Alt+Del and stop the Subsonic process, reopen again and i always get "Address already in use. Please change port number."
Hope someone can help
Problem Description: I tried many ports, none of them seem to work. The same ports work on other XP machines where i have Subsonic (same Network)
Troubleshooting Steps: Re-installed many times, installed as admin
Playback Application and version: Havent managed to open the web site yet
Subsonic Version: Havent managed to open the web site yet
Server Version: Havent managed to open the web site yet
Hardware Platform: Windows 7 Ultimate
Java Memory Limit: 100mb
Java Version: 6 update 26
Problem Filename: N/A
Output from ffmpeg -i: N/A
This is the subsonic-server.log found on c:\program files\subsonic:
343 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@14a9972: display name [org.springframework.context.support.ClassPathXmlApplicationContext@14a9972]; startup date [Mon Jun 13 16:39:28 CEST 2011]; root of context hierarchy
390 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-deployer.xml]
1747 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@14a9972]: org.springframework.beans.factory.support.DefaultListableBeanFactory@ef5502
2028 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@ef5502: defining beans [service,org.springframework.remoting.rmi.RmiServiceExporter#0]; root of factory hierarchy
3011 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger(org.mortbay.log) via org.mortbay.log.Slf4jLog
Using WAR file: C:\Program Files\Subsonic\subsonic.war
Extracting webapp to c:\subsonic\jetty\2172
6162 [main] INFO org.mortbay.log - jetty-6.1.x
7239 [main] INFO org.mortbay.log - Extract jar:file:/C:/Program%20Files/Subsonic/subsonic.war!/ to C:\subsonic\jetty\2172\webapp
46549 [main] INFO / - Initializing Spring root WebApplicationContext
46549 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization started
46580 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@11e0c13: display name [Root WebApplicationContext]; startup date [Mon Jun 13 16:40:15 CEST 2011]; root of context hierarchy
46634 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-service.xml]
46750 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-security.xml]
46822 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-cache.xml]
46874 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@11e0c13]: org.springframework.beans.factory.support.DefaultListableBeanFactory@b60b93
47350 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@b60b93: defining beans [playerDao,internetRadioDao,musicFileInfoDao,musicFolderDao,userDao,transcodingDao,podcastDao,avatarDao,daoHelper,musicFileService,securityService,settingsService,searchService,luceneSearchService,networkService,playerService,playlistService,versionService,statusService,musicInfoService,musicIndexService,audioScrobblerService,transcodingService,podcastService,adService,jukeboxService,metaDataParserFactory,ajaxMultiService,ajaxNowPlayingService,ajaxPlaylistService,ajaxLyricsService,ajaxCoverArtService,ajaxTagService,ajaxTransferService,ajaxChatService,filterChainProxy,httpSessionContextIntegrationFilter,logoutFilter,authenticationProcessingFilter,basicProcessingFilter,restRequestParameterProcessingFilter,basicProcessingFilterEntryPoint,securityContextHolderAwareRequestFilter,rememberMeProcessingFilter,anonymousProcessingFilter,exceptionTranslationFilter,basicExceptionTranslationFilter,filterInvocationInterceptor,accessDecisionManager,rememberMeServices,authenticationManager,daoAuthenticationProvider,userCacheWrapper,ldapAuthenticationProvider,bindAuthenticator,userDetailsServiceBasedAuthoritiesPopulator,ajaxServiceInterceptor,ajaxTagServiceSecure,ajaxTransferServiceSecure,cacheManager,userCache,musicFileCache,childDirCache,coverArtCache,musicFolderCache,chatCache]; root of factory hierarchy
48845 [main] INFO org.springframework.jdbc.datasource.DriverManagerDataSource - Loaded JDBC driver: org.hsqldb.jdbcDriver
52694 [main] INFO org.springframework.cache.ehcache.EhCacheManagerFactoryBean - Initializing EHCache CacheManager
Jun 13, 2011 4:40:21 PM net.sf.ehcache.CacheManager addShutdownHookIfRequired
INFO: The CacheManager shutdown hook is enabled because net.sf.ehcache.enableShutdownHook is set to true.
Jun 13, 2011 4:40:22 PM net.sf.ehcache.Cache initialise
WARNING: Cache: musicFolderCache has a maxElementsInMemory of 0. It is strongly recommended to have a maximumSize of at least 1. Performance is halved by not using a MemoryStore.
WARNING: Cache: chatCache has a maxElementsInMemory of 0. It is strongly recommended to have a maximumSize of at least 1. Performance is halved by not using a MemoryStore.
57972 [main] INFO org.acegisecurity.intercept.AbstractSecurityInterceptor - Validated configuration attributes
57997 [main] INFO org.acegisecurity.intercept.method.MethodDefinitionMap - Adding secure method [public net.sourceforge.subsonic.ajax.UploadInfo net.sourceforge.subsonic.ajax.TransferService.getUploadInfo()] with attributes [[ROLE_UPLOAD]]
57997 [main] INFO org.acegisecurity.intercept.method.MethodDefinitionMap - Adding secure method [public java.lang.String net.sourceforge.subsonic.ajax.TagService.setTags(java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String)] with attributes [[ROLE_COVERART]]
57997 [main] INFO org.acegisecurity.intercept.AbstractSecurityInterceptor - Validated configuration attributes
58023 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization completed in 11474 ms
60546 [main] INFO / - Initializing Spring FrameworkServlet 'subsonic'
60546 [main] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'subsonic': initialization started
60546 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@1f195fc: display name [WebApplicationContext for namespace 'subsonic-servlet']; startup date [Mon Jun 13 16:40:29 CEST 2011]; parent: org.springframework.web.context.support.XmlWebApplicationContext@11e0c13
60547 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/subsonic-servlet.xml]
60640 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@1f195fc]: org.springframework.beans.factory.support.DefaultListableBeanFactory@a030d6
60831 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@a030d6: defining beans [leftController,rightController,statusController,mainController,topController,helpController,moreController,uploadController,lyricsController,allmusicController,podcastController,podcastReceiverController,podcastReceiverAdminController,setMusicFileInfoController,setRatingController,randomPlaylistController,loadPlaylistController,savePlaylistController,changeCoverArtController,nowPlayingController,searchController,settingsController,playerSettingsController,musicFolderSettingsController,networkSettingsController,transcodingSettingsController,internetRadioSettingsController,podcastSettingsController,searchSettingsController,generalSettingsController,advancedSettingsController,personalSettingsController,avatarUploadController,userSettingsController,passwordSettingsController,homeController,editTagsController,playlistController,xspfPlaylistController,coverArtController,avatarController,proxyController,statusChartController,userChartController,m3uController,streamController,videoPlayerController,downloadController,donateController,multiController,wapController,restController,dbController,savePlaylistValidator,donateValidator,userSettingsValidator,passwordSettingsValidator,urlMapping,messageSource,themeSource,localeResolver,themeResolver,viewResolver]; parent: org.springframework.beans.factory.support.DefaultListableBeanFactory@b60b93
61252 [main] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'subsonic': initialization completed in 706 ms
61972 [main] WARN org.mortbay.log - failed SelectChannelConnector@0.0.0.0:80
java.net.BindException: Address already in use: bind
   at sun.nio.ch.Net.bind(Native Method)
   at sun.nio.ch.ServerSocketChannelImpl.bind(Unknown Source)
   at sun.nio.ch.ServerSocketAdaptor.bind(Unknown Source)
   at org.mortbay.jetty.nio.SelectChannelConnector.open(SelectChannelConnector.java:211)
   at org.mortbay.jetty.nio.SelectChannelConnector.doStart(SelectChannelConnector.java:309)
   at org.mortbay.jetty.Server.doStart(Server.java:228)
   at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.deployWebApp(SubsonicDeployer.java:131)
   at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.<init>(SubsonicDeployer.java:65)
   at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
   at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
   at java.lang.reflect.Constructor.newInstance(Unknown Source)
   at net.sourceforge.subsonic.booter.Main.<init>(Main.java:16)
   at net.sourceforge.subsonic.booter.Main.main(Main.java:24)
   at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
   at java.lang.reflect.Method.invoke(Unknown Source)
   at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
   at com.exe4j.runtime.WinLauncher$1.run(Unknown Source)
61974 [main] WARN org.mortbay.log - failed Server@12cb585
62012 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
63019 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
64063 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'SubsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[192.168.1.103:9412](local),objID:[0:0:0, 0]]]]
sbnic
Postby GJ51 » Mon Jun 13, 2011 3:15 pm
