alphawave7 wrote:On the pc hosting Subsonic, go into lan settings, Internet Protocol (TCP/IP), and UNcheck 'Obtain an IP address automatically' and instead select 'Use The Following IP Address'
IP 192.168.1.2
Subnet 255.255.255.0
Gateway 192.168.1.1 (assuming your router is 1.1)
Reboot after this change, and ensure the new settings stick. Then, using your router's manual, open your chosen port number (eg. 8080) for TCP, and reboot your router. Ensure the new settings stuck, and test with canyouseeme.org for your chosen port number. G'Luck!
vancamp wrote:alphawave7 wrote:On the pc hosting Subsonic, go into lan settings, Internet Protocol (TCP/IP), and UNcheck 'Obtain an IP address automatically' and instead select 'Use The Following IP Address'
IP 192.168.1.2
If you hard-wire the address on the PC (rather than reserve it on the router) you should also make sure that the router doesn't think that address still belongs to its DHCP address pool. Otherwise there could be scenarios where the address is assigned twice... not so good.
