Lame running in Windows
Postby PiX64 » Tue Jun 14, 2011 8:50 pm
Hello all, I am new here. I have been browsing around the forum to see if I can find an answer to my question but i dont' seem to be able to locate anything of use.
the issue i am having is that i have a UNC location i am using on my unraid server in order to access my music from the windows machine where i have subsonic running.
everythign works fine from that perspective and I am able to play music, stream, update everything. The issue i am having is when LAME trys to encode a file for use over a limited bandwidth connection like 3g. I have the subsonic player for my device set to 128 kbps, but i continue to get the following errors in my log file:
2011-06-14 14:20:45,078] WARN TranscodingService - Failed to transcode \\192.168.1.26\Music\Halestorm\ReAniMate_ The CoVeRs EP\01 - Halestorm - Slave To The Grind.mp3. Using original.
java.io.IOException: Cannot run program "c:\subsonic\transcode\lame": CreateProcess error=193, %1 is not a valid Win32 application
   at java.lang.ProcessBuilder.start(Unknown Source)
   at net.sourceforge.subsonic.io.TranscodeInputStream.<init>(TranscodeInputStream.java:61)
   at net.sourceforge.subsonic.service.TranscodingService.createTranscodeInputStream(TranscodingService.java:358)
   at net.sourceforge.subsonic.service.TranscodingService.getDownsampledInputStream(TranscodingService.java:386)
   at net.sourceforge.subsonic.service.TranscodingService.getTranscodedInputStream(TranscodingService.java:219)
   at net.sourceforge.subsonic.io.PlaylistInputStream.prepare(PlaylistInputStream.java:130)
   at net.sourceforge.subsonic.io.PlaylistInputStream.read(PlaylistInputStream.java:94)
   at net.sourceforge.subsonic.io.PlaylistInputStream.read(PlaylistInputStream.java:86)
   at net.sourceforge.subsonic.controller.StreamController.handleRequest(StreamController.java:202)
   at net.sourceforge.subsonic.controller.RESTController.stream(RESTController.java:746)
   at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
   at java.lang.reflect.Method.invoke(Unknown Source)
   at org.springframework.web.servlet.mvc.multiaction.MultiActionController.invokeNamedMethod(MultiActionController.java:473)
   at org.springframework.web.servlet.mvc.multiaction.MultiActionController.handleRequestInternal(MultiActionController.java:410)
   at net.sourceforge.subsonic.security.RESTRequestParameterProcessingFilter.doFilter(RESTRequestParameterProcessingFilter.java:122)
Caused by: java.io.IOException: CreateProcess error=193, %1 is not a valid Win32 application
   at java.lang.ProcessImpl.create(Native Method)
   at java.lang.ProcessImpl.<init>(Unknown Source)
   at java.lang.ProcessImpl.start(Unknown Source)
   ... 69 more
Lame is installed and if i use the mapped network drive to try and encode the stream it will work correctly. if i try running lame on the UNC location from the command prompt it will not run. it always tells me that it cannot find the file.
Any suggestions or ideas?
I was running subsonic on my unraid box, but wanted to be able to use the jukebox feature. I didn't want to mess with the unraid kernel and getting the correct modules loaded on unraid in order to get sound output...[/code]
PiX64
Postby PiX64 » Thu Jun 16, 2011 7:06 pm
*bump*
anyone?
PiX64
