Build the android app
Postby trishikaac » Wed Jun 22, 2011 11:55 am
I'd like to build the android app from source.
On the /trunk/subsonic directory I try these commands:
% ant clean
Buildfile: /home/aurelien/subsonic/trunk/subsonic-android/build.xml
BUILD FAILED
/home/aurelien/subsonic/trunk/subsonic-android/build.xml:49: taskdef class com.android.ant.SetupTask cannot be found
using the classloader AntClassLoader[]
Total time: 0 seconds
% ant release
BUILD FAILED
Thanks for your help.
trishikaac
Postby sindre_mehus » Wed Jun 22, 2011 2:50 pm
Try to modify "sdk.dir" in local.properties
Postby trishikaac » Wed Jun 22, 2011 4:16 pm
Thanks a lot ! Works fine.
First time building an android app this way ^^
trishikaac
