AAC (m4a), FLAC file probs
Postby espressodaily » Thu Jun 23, 2011 3:03 pm
MP3 FILES play fine everywhere (browser, subair, iphone/ipad)
AAC files don't play in browser or subair
FLAC files don't play in anything.
espressodaily
Postby yourlord » Thu Jun 23, 2011 4:27 pm
Well, with the over abundance of information you've provided I'm sure a solution is forthcoming..
Can we get some logs from subsonic?
yourlord
Postby espressodaily » Mon Jun 27, 2011 7:23 pm
yourlord wrote:Well, with the over abundance of information you've provided I'm sure a solution is forthcoming..
Your comment is well justified, sorry. I was on the road at the time and was hoping it was a setting that I missed.
Log file says this for the songs I just tried:
AAC
[2011-06-27 14:34:40,361] INFO PlaylistInputStream - espressodaily listening to "Brotherhood/01 The Go Getter.m4a"
[2011-06-27 14:42:41,841] INFO RESTRequestParameterProcessingFilter - Authentication failed for user null
[2011-06-27 14:43:00,295] INFO PlaylistInputStream - espressodaily listening to "Brotherhood/01 The Go Getter.m4a"
[2011-06-27 14:43:15,114] WARN LyricsService - Failed to get lyrics for song 'The+Go+Getter'.
java.net.SocketTimeoutException: Read timed out
FLAC
[2011-06-27 14:49:08,743] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-i] [/mnt/music/FLAC/Albums/Daughtry/Daughtry~Daughtry~09~Gone~Rock~2006.flac] [-f] [wav] [-]
[2011-06-27 14:49:08,786] WARN TranscodingService - Failed to transcode /mnt/music/FLAC/Albums/Daughtry/Daughtry~Daughtry~09~Gone~Rock~2006.flac. Using original.
java.io.IOException: Cannot run program "/var/subsonic/transcode/ffmpeg": java.io.IOException: error=2, No such file or directory
espressodaily
Postby yourlord » Tue Jun 28, 2011 10:59 pm
It looks like you don't have ffmpeg in /var/subsonic/transcode
you either need a symbolic link to the executable in there, or a copy of the actual file.
yourlord
Re: AAC (m4a), FLAC file probs
Postby steve1977 » Sat Sep 10, 2011 3:37 am
Having a similar issue. Apple Lossless (M4A) does not play in the web player. The log does not give any indication:
[2011-09-10 11:30:51,935] INFO PlaylistInputStream - admin listening to "The Lady Killer\01 Lady Killer Theme (intro).m4a"
Also, I do not receive any error message. When selecting the song in the web player, it starts "downloading/caching" the song, but even after reaching 100%, it does not start playing.
Any thoughts are highly appreciated!!!
steve1977
Postby BKKKPewsey » Sat Sep 10, 2011 3:23 pm
As JW player will play m4a files natively there shouldn't be a problem.
Obviously test that track does play ok in another media player then create another player in SS and try using that.
