Adding Windows shared folder to Subsonic running on Ubuntu
Postby ACTPOHABT » Sat Jun 25, 2011 10:54 pm
Hello there!
I'm trying to add folder that is located on my second pc running windows 7 to Subsonic's "Music folders" tab under Ubuntu 11.04. It shows mounted in Nautilus as smb://my-pc/users/USERNAME/Music. Does anyone know what the correct path would be when I add it in Subsonic "Music folders" menu in web browser? Thank you!
ACTPOHABT
Postby GJ51 » Sat Jun 25, 2011 11:25 pm
Just open windows explore (Not IE) and browse to the folder. Click on the address line and copy the share address that windows uses. If it's a local drive, just use the \\Computername\directory\subdirectory.
e.g.: \\MAPLEGROVE\Music\Music CD
Postby ACTPOHABT » Sat Jun 25, 2011 11:50 pm
GJ51 wrote:Just open windows explore (Not IE) and browse to the folder. Click on the address line and copy the share address that windows uses. If it's a local drive, just use the \\Computername\directory\subdirectory.
I'm on Ubuntu. The folder with music is shared from Windows 7 PC. And by the way, do I use back slashes or forward slashes?
ACTPOHABT
Postby GJ51 » Sun Jun 26, 2011 12:01 am
Sorry, I'm just a Windows guy. I can access dhares on any computer on my network using the format I described above. I think that conforms to UNC. On my systems \\MAPLEGROVE\Music\OGG Music\Buffalo Springfiled would be an example of how to access a folder on a different computer.
Give that a try. I'm not sure what you have to do in Ubuntu to set up autorization for folder access, but the basic format should be correct.
Postby ACTPOHABT » Sun Jun 26, 2011 12:06 am
Tried everything. Nothing worked. That's why I posted here :)
ACTPOHABT
Postby GJ51 » Sun Jun 26, 2011 12:17 am
Sorry, I can only give you info from the Windows side, hopefully one of the Linix guys will chime in. If you don't get a post soon try sending a pm to one of the more frequent Linix posters.
Re: Adding Windows shared folder to Subsonic running on Ubun
Postby Aethies » Sun Jun 26, 2011 3:36 pm
ACTPOHABT wrote:Hello there!
I am testing that now. I am not sure how it is going to work since Windows 7 has incorporated sharing only in your HOMEGROUP. I am building some additional network tools to try to connect to my windows 7 box from my Gentoo box. I will let you know what I find. I am hoping I just get a prompt for the homegroup password and it allows me access. I don't have high hopes though, given how M$ is notorious for not playing nice with Linux.
Be getting back to you soon.
Aethies
Ubuntu Server 12.04
3,281 artists
9,432 albums
113,608 songs
2636.09 GB (10,769 hours)
Aethies
Postby Aethies » Sun Jun 26, 2011 4:39 pm
Ok, so good news. I was initially presented with a credentials screen, so I entered them in. I was able to see shares on my windows 7 pc including the specific folder that I shared. That being said, you can do this easily.
1. You need to make sure the network share is mounted in ubuntu on startup if you want to have access all the time to this music folder in subsonic.
2. Once you have this network share mount point, then you can point subsonic to the share.
I think what you are trying to do is tell subsonic the network share name. That could be your problem.
In your /etc/fstab, at the bottom, add the following line in the exact format as this:
//win-pc/folder that is shared   /media/music    cifs    username=server_user,password=server_password,uid=1000,gid=users 0 0
So you are telling ubuntu to mount win-pc/musicfolder to /media/music using cifs (samba). I found that line regarding the username on forums that allows you to mount it with no user/pass.
When you have saved your /etc/fstab, don't forget to create the /media/music folder.
# mkdir /media/music
# chown yourusername:yourusername /media/music (this changes the owner of the folder to you, instead of root)
Now that that line is in fstab, it will mount it at boot time. You can manually mount it with the following:
# mount /media/music
Once that is mounted, in Subsonic, point your music folder to /media/music
NOTE: sudo works as well, i.e. sudo mount /media/music if you are not root.
Hope this helps. If you need any further info, please send me a pm.
Aethies
Aethies
Postby ACTPOHABT » Mon Jun 27, 2011 9:43 pm
You are my savior! Thank you so much!
Instead of "win-pc" had to enter internal IP address (10.0.0.X) and media/music folder had to go inside of my home directory. The rest left unchanged. Everything works now!
Thank you again!!!
ACTPOHABT
Postby baaldemon » Tue Jun 28, 2011 10:48 am
I would recommend using a credentials file rather than having your plaintext credentials in the world readable fstab file. Its the same syntax as what is already listed, but rather than having username=un,password=pw replace that with credentials=/etc/.smbpass (you can name the file whatever you want)
and then in the file /etc/.smbpass
username=user
password=password
Then run
chmod 600 /etc/.smbpass
chown root:root /etc/.smbpass
baaldemon
Postby Aethies » Tue Jun 28, 2011 1:39 pm
baaldemon wrote:I would recommend using a credentials file rather than having your plaintext credentials in the world readable fstab file. Its the same syntax as what is already listed, but rather than having username=un,password=pw replace that with credentials=/etc/.smbpass (you can name the file whatever you want)
username=user
password=password
Then run
I didn't want to get too cryptic in mounting shares. But that is definitely recommended to ensure a more secure setup.
Aethies
Ubuntu Server 12.04
3,281 artists
9,432 albums
113,608 songs
Aethies
Network share question
Postby Fastbob » Sat Jul 30, 2011 4:55 pm
Aethies, you are my hero!
I have look up and down the internet to get this thing going as you described.
I have tried to get it going but somehow I did not reach the finish line yet.
My situation: I have NAS where my music and movies are stored.
The NAS has users w. passwords.
My Subsonic is running on webserver with ClearOS 5.1 (a linux based free all-in-one package). Subsonic installed etc. It works besides the network share (it works on my windows server where I have logged on to the NAS)
Now, excuse me for asking these simple questions but somehow I am missing something, somehere.
I have followed your guideline and tried several options regarding the usernames but I did not manage yet to get it working.
I have added the share in the fstab file. I do suppose my actual login data for the NAS should be used after "cifs".....right?
I entered "mkdir" command at the command line of my midgnight commander and added the chown command to. But tell me what username:username should be used here?
Or should I add both incl. the mount command to a specific file (fstab??)
I suppose if I enter this in a file it would mount automatically when I boot.
The strange thing is that since I tried this Subsonic did not show the "no media folders found" error but my music is not shown (yet).
Fastbob
Fastbob
Postby Aethies » Sat Jul 30, 2011 5:13 pm
Yes.. if the line is in fstab, it will mount it upon boot.
the only thing you need to change in this line is the //win-pc/folder and the /media/music. The rest should stay the same.
One thing I forgot to mention.. when you add this line into the fstab, you can then mount the share manually by typing
it will pull the settings from the fstab.
let me know if that helps
Aethies
Postby Fastbob » Sun Jul 31, 2011 10:01 am
Hi Aethies,
Yes, it took some time but it works, Super!!
4.092 artiesten
1.675 albums
25.119 nummers
701,82 GB (~ 10.902 uur)
Many thanks.
Fastbob
Fastbob
Postby Ian090471Wheeler » Sat Aug 20, 2011 9:14 pm
Hello folks
new here, first things first: nice app
This is the sort of stuff I am trying to do, but without the technical level of knowledge you guys have.
I am running subsonic 4.5 (build 2385) – August 11, 2011 on an xp sp3 machine and trying to access through a android tablet M7 (android 2.2 - 2.3).
Set up all ok - (only user on subsonic admin) can access my music on my c: on the tablet but no joy on the NAS I mapped to my pc (linkstation). I have tried to change the log in tab on the service but no good. All I get is "Could not Start Subsonic service on Local Computer Error 1069: The service did not start due to log on failure"
I have tried user Admin no password and my log in no password, but not joy (no passwords set up)
Can you help me with what I am missing?
Can you point me in the right direction please ?
Also, on my tablet I can not see my internet radio set up in web brouser when I log on with my tablet it would be nice to see it, can I?
Also last question if I sort the Nas problem out can I access direct without having to turn on my pc, that would be really cool?
Ian090471Wheeler
