FLAC: "file is not a supported file type"
Postby wilbert-vb » Sun Jun 26, 2011 8:25 pm
Hello there
Today I started evaluating subsonic 4.4 on a FreeBSD-8.2 system.
I like to listen to my flac collection (stored on the local drive) in jukebox mode.
Unfortunately, I get this error:
[2011-06-26 14:50:10,650] INFO JukeboxService - Starting jukebox player on behalf of wilbert
[2011-06-26 14:50:10,651] DEBUG JukeboxService - stateUpdated : OPENING:-1:java.io.BufferedInputStream@6a4fda
[2011-06-26 14:50:10,654] INFO PlaylistInputStream - wilbert listening to "02/01_Summer Night City.flac"
[2011-06-26 14:50:10,682] WARN JukeboxService - Error in BasicPlayer.play()
javax.sound.sampled.UnsupportedAudioFileException: file is not a supported file type
   at javax.sound.sampled.AudioSystem.getAudioFileFormat(AudioSystem.java:1010)
   at net.sourceforge.subsonic.service.JukeboxService$JuxeboxPlayer$1.initAudioInputStream(JukeboxService.java:144)
   at javazoom.jlgui.basicplayer.BasicPlayer.initAudioInputStream(Unknown Source)
   at javazoom.jlgui.basicplayer.BasicPlayer.open(Unknown Source)
   at net.sourceforge.subsonic.service.JukeboxService$JuxeboxPlayer.play(JukeboxService.java:153)
   at net.sourceforge.subsonic.service.JukeboxService.play(JukeboxService.java:76)
   at net.sourceforge.subsonic.ajax.PlaylistService.convert(PlaylistService.java:284)
   at net.sourceforge.subsonic.ajax.PlaylistService.play(PlaylistService.java:118)
   at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
   at java.lang.reflect.Method.invoke(Method.java:616)
   at org.directwebremoting.impl.DefaultRemoter$1.doFilter(DefaultRemoter.java:740)
   at org.directwebremoting.impl.DefaultRemoter.execute(DefaultRemoter.java:744)
   at org.directwebremoting.impl.DefaultRemoter.execute(DefaultRemoter.java:593)
   at org.directwebremoting.dwrp.BaseCallHandler.handle(BaseCallHandler.java:90)
   at org.directwebremoting.servlet.UrlProcessor.handle(UrlProcessor.java:120)
   at org.directwebremoting.servlet.DwrServlet.doPost(DwrServlet.java:141)
   at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
   at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:844)
   at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:644)
   at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:205)
[2011-06-26 14:51:18,620] ERROR JukeboxService - Error in BasicPlayer.setGain()
[2011-06-26 14:51:25,063] ERROR JukeboxService - Error in BasicPlayer.setGain()
I hope for suggestions how to fix this?
Also, I have a suggestion for you.
In most unix based systems, the start script reads a conf file in /etc (/usr/local/etc), so I have a tiny bit of code for you to include in the next version, if you like:
SUBSONIC_CONF=/usr/local/etc/$(basename $0 .sh).conf
# Read systemwide config file
if [ -e "${SUBSONIC_CONF}" ]
    then
    echo Including settings from "${SUBSONIC_CONF}"
    . "${SUBSONIC_CONF}"
fi
And I have the settings in /usr/local/etc/subsonic.conf.
Neat, hm?
wilbert-vb
