[BUG] Forced HTTPD Redirect
Postby BigWookie » Fri Jul 08, 2011 12:18 pm
First of all, Thanks!
When having SSL Enabled, the non-ssl port redirects to the ssl port.
To use streaming I set the port to the http port ( also tried another port to see if it creates a new listener ) and try to connect.
Problem is that even the stream gets redirected to https ( or tries to ), from mplayer log: Unsupported http 302 redirect to https protocol .
BigWookie
