GJ51 wrote:You can set the bit rate either way. If you assign a max bit rate to a user, then all the players that are created for that user will be limited.
On the other hand you may have a particular player configuration that you'd like to configure without restricting other players created for the same user.
Very flexible.
For instance, you may want to lower the bitrate for your mobile device, yet use the full bitrate on your desktop. By adjusting settings for each player you can do that. If you lowered the rate for yourself in the user settings then both environments would play at the lower rate.
HTH
