Getting an error..
Getting an error..
Postby DanesDK » Thu Jul 14, 2011 2:03 pm
I have installed SubSonic.
Opened port 8089 in my router, tpc/udp to my local ip
I have changed the port no in SS CP.
But when im trying to open my "subsonic", i get this error:
Exception java.lang.OutOfMemoryError
Message Java heap space
Java version Sun Microsystems Inc. 1.6.0_24
Server jetty-6.1.x
Memory Used 96 of 96 MB
Stack trace java.lang.OutOfMemoryError: Java heap space at org.apache.xerces.dom.DeferredDocumentImpl.createChunk(Unknown Source) at org.apache.xerces.dom.DeferredDocumentImpl.ensureCapacity(Unknown Source) at org.apache.xerces.dom.DeferredDocumentImpl.createNode(Unknown Source) at org.apache.xerces.dom.DeferredDocumentImpl.createDeferredTextNode(Unknown Source) at org.apache.xerces.parsers.AbstractDOMParser.ignorableWhitespace(Unknown Source) at org.apache.xerces.impl.dtd.XMLDTDValidator.characters(Unknown Source) at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanContent(Unknown Source) at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown Source) at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source) at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source) at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source) at org.apache.xerces.parsers.XMLParser.parse(Unknown Source) at org.apache.xerces.parsers.DOMParser.parse(Unknown Source) at org.apache.xerces.jaxp.DocumentBuilderImpl.parse(Unknown Source) at org.apache.jasper.xmlparser.ParserUtils.parseXMLDocument(ParserUtils.java:95) at org.apache.jasper.xmlparser.ParserUtils.parseXMLDocument(ParserUtils.java:132) at org.apache.jasper.compiler.TldLocationsCache.getUriFromTld(TldLocationsCache.java:465) at org.apache.jasper.compiler.TldLocationsCache.scanJar(TldLocationsCache.java:372) at org.apache.jasper.compiler.TldLocationsCache.scanJars(TldLocationsCache.java:517) at org.apache.jasper.compiler.TldLocationsCache.init(TldLocationsCache.java:249) at org.apache.jasper.compiler.TldLocationsCache.getLocation(TldLocationsCache.java:224) at org.apache.jasper.JspCompilationContext.getTldLocation(JspCompilationContext.java:526) at org.apache.jasper.compiler.Parser.parseTaglibDirective(Parser.java:422) at org.apache.jasper.compiler.Parser.parseDirective(Parser.java:492) at org.apache.jasper.compiler.Parser.parseElements(Parser.java:1552) at org.apache.jasper.compiler.Parser.parse(Parser.java:126) at org.apache.jasper.compiler.ParserController.doParse(ParserController.java:211) at org.apache.jasper.compiler.ParserController.parse(ParserController.java:116) at org.apache.jasper.compiler.Parser.processIncludeDirective(Parser.java:335) at org.apache.jasper.compiler.Parser.parseIncludeDirective(Parser.java:372) at org.apache.jasper.compiler.Parser.parseDirective(Parser.java:484) at org.apache.jasper.compiler.Parser.parseElements(Parser.java:1552)
And when i try to login via my HTC, i get a "A network error occurred.."
Any idea..?
DanesDK
Postby alphawave7 » Thu Jul 14, 2011 2:36 pm
Stop the service and use console to increase available Java memory...try 256 MB.
Postby DanesDK » Thu Jul 14, 2011 5:11 pm
Thanks, that did the job..
But do you know why, i cant get it to work
on other ports than 80.. ?
I have tryed to make a Port Forwarding to port 8089 and put
that in SS CP..
But it does not work
DanesDK
