login problem
login problem
Postby becks87 » Mon Jul 18, 2011 4:12 pm
hello, i went to the setting in the web browser (safari for MAC)
i add the user and the password hit save and when i try to log in on my phone i keep getting the wrong user or password message.... its really making me mad,
please help
becks87
Postby alphawave7 » Mon Jul 18, 2011 7:32 pm
Stop server and restart, then retry.
Post subject: login problem
Postby cporter82 » Mon Jul 18, 2011 9:33 pm
I had today the same problem, but the login failed at the web interface, I couldn't login as admin to the web app but it worked fine from my android.
So I restarted the service which is running within ubuntu 10.10 desktop, but it didn't worked neither.
Then I removed the package doing dpkg --purge subsonic but the configuration files at /var/lib/subsonic weren't removed, so to reinstall the package didn't solved the problem.
Then I modified the file subsonic.script as per the instruccions on this site: http://blog.gerke-preussner.de/2010/12/ ... -streamer/
That didn't worked neither... So I assumed that the site was compromissed, I set up the firewall rules to block all the services to the internet.
Finally, I removed the package again, then renamed /var/lib/subsonic as /var/lib/subsonic_old and reinstalled the subsonic package again.
The service came back with the default settings.
So I strongly suspect that my home server has been compromised, however I can't explain why my password worked with the Android App but not with the Browser App (no caps on by the way...), I still have the original conf files from this morning if somebody can perform a forencic analasys to find out if it's an application problem, but I preffer to play same and reinstall the whole OS.
Regards.
cporter82
