cannot get adroid to stream
Postby revaew » Thu Jul 21, 2011 7:22 am
Problem Description:so i followed the guide in the documentation sections to the T. i did the local streaming thing (visit http://yourname.subsonic.org) to verify and what not and it works on some of the computers in my house and when i try to use the app, i cannot connect to the server
Troubleshooting Steps: searched the forums for solutions. tried what i saw. tried fowarding ports and what not. on canyouseeme i cannot be seen. reason is that the connection timed out
Playback Application and version: i am using the current app from the android market
Subsonic Version: 4.5.beta1 (build 2289) – June 19, 2011
Server Version: jetty-6.1.x, java 1.6.0_23, Windows 7 (41.1 MB / 58.1 MB)
Hardware Platform: (Windows 7 64 bit home premium
Java Memory Limit: 100 mb
Problem Filename: N/A
Output from ffmpeg -i: N/A?
Last ten log file lines:
[7/21/11 2:59:22 AM EDT]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) [aac @ 036f0240]channel element 3.0 is not allocated
[7/21/11 2:59:22 AM EDT]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) Error while decoding stream #0.1
[7/21/11 2:59:22 AM EDT]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) [aac @ 036f0240]SBR not implemented. Update your FFmpeg version to the newest one from SVN. If the problem still occurs, it means that your file has a feature which has not been implemented.
[7/21/11 2:59:22 AM EDT]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) [libmp3lame @ 013aa7a0]lame: output buffer too small (buffer index: 9404, free bytes: 388)
[7/21/11 2:59:22 AM EDT]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) Audio encoding failed
[7/21/11 3:00:00 AM EDT]   INFO   SearchService   Starting to create search index.
[7/21/11 3:00:28 AM EDT]   INFO   SearchService   Created search index with 1000 entries.
[7/21/11 3:00:47 AM EDT]   WARN   JaudiotaggerParser   Error when parsing tags in C:\Users\malachi\Music\iTunes\iTunes Media\Podcasts\Learn German for free with German-Podcas\Learn to speak German - Lesson 023 - 2.mp3
[7/21/11 3:01:39 AM EDT]   INFO   SearchService   Created search index with 2000 entries.
[7/21/11 3:02:40 AM EDT]   INFO   SearchService   Updating Lucene search index.
[7/21/11 3:02:41 AM EDT]   INFO   SearchService   Created search index with 2349 entries
edit: nevermind. i refowarded ports like seven hundred times and it works now
revaew
